ahhh bloody air boats lol
Hi got my new boat from the usa thought great stuck an old engine onto it tried it and it went very fast thought great then stuck my good engine on it took it off my tank boat!!
then i got problems noticed that the back of the hull was cracked opened it up as that where the fuel tank was
it was leaking so out it came cleaned out the hull a few buckets of nice hot water with washing liquid in it did the job!
then i put fibre glass resin in the hull after i pinned it back together worked fine
then put a fuel tank up top behind the engine took it out my god it had double the power then i got home looked at it the prop had half an inch between it and the hull the engine must have been going that fast the prop had started to dig a hole in the wooden hull see pic
So I put two half inch blocks of wood under each side of the engine mount to give it an inch clearance now the thing is top heavy had it out today seemed to tilt when i was turning it
I have tried a 3 blade prop but it did not have that much power im using a 10" prop at the mo think its a ten by 6
it works fine but I never thought a wee 40 rmx engine could make a prop grow by more than half an inch must be going rather fast to do that the boat is meant to run on a 60 my god it be like a bullet if it did and don't think i be able to control it
but its great i have a real air boat now that is fantastic
Fixed it moved the engine back down fuel tank up top seems to make it a bit top heavy think it mite tip over got to get engine tuned again as i took off my fuel filter as it was a bit mucky yip dirt went into carb silly me here it is
http://www.youtube.com/watch?v=5tUmsZga35E
UP date fuel tank up top made it a bit top heavy I have now fitted a 16oz tank in the hull hopefully this one not leak filled the hull with resin so it should be okay i have fitted a 2oz tank up top so 16oz tank and the 2oz tank 18oz fuel should give me a good run time try it tomorrow bought a telescopic fishing pole its 14foot that should get it back in lol will post a film thanks every one for your thoughts
MI
RE: ahhh bloody air boats lol
Your prop is not growing . Your engine stand is flexing forward letting your prop touch the deck or you may have something comming loose or unglued .
Thank you I will take off the extra bits make it same size it did try and eat a bush at the side of the canal that would not have helped
now think to myself why did i glue on the extra wood this be fun getting it off thank you for your help kind regards stewart
You mat be able to make some type of support from the top bolts of the fire wall engine mount to the top rear of the base plate. This may help the plate from bending or flexing. Like the bracket that is now in the center, make something like that on each side. Your best bet would be to make a stand like what Don has on his post.
I dont think its the mount flexing ,its probably the deck flexing where the mount fixes to the deck area ? but i could be wrong as bush as caused a bit of trouble before I just want to make myself clear, I wasn`t talking about George,
