Carolina SI build
NC
Carolina SI build
I could not wait for the laser cut version to come out so I had Chris cut me one instead. She should be ready for the water in a week or so.
RE: Carolina SI build
Lookin good, whats the size, and what engine are you using ? for some strange reason it makes me think "scorpion" [sm=bananahead.gif]
NC
Thanks Rick.
This has been a great kit to build. It even has the fun factor built into it. Here power plant is a OS.46 AX (BUT) she will also handle a .61. Since it been a very easy build I can't remember the spec. The only time I pulled out a measuring tape was setting the rudder. Everything was layed out perfectly for me.
FL
Andy, you've done a fine job putting it together! Your right, this boat is not only fun to build but is very simple to put together. Every piece has its resting spot already laid out for you. Its like painting by numbers, just put the piece on the lines which are on the deck. You are going to enjoy running this boat. It is fast, stable, and very controllable. Can't wait for June to run with ya! [8D][8D]
Rick, if your interested in seeing this boat in action, here is a few links for you. These videos are from the very first 3 pointer I made. The boat Andy has is the predecessor to the first. I have a laser cut kit coming out in the near future of this design.
[link=http://www.rc-airboats.com/gallery/albums/ABW-Videos/First_SI_3_Pointer.wmv]Maiden Voyage of the first prototype.[/link]
Some adjustments have been made from this original prototype.
[link=http://www.rc-airboats.com/gallery/albums/Chris-Selph/43_3_SI_3_Pointer.wmv]My first 3 pointer hitting 43.3 mph.[/link]
Andy, keep up the good work!! You know I just thought of something......I see an Evo 1.0 in the picture. I wonder how that would act on the 3 pointer? [8D]
SI, I'm seeing some design flaws, you may want to reconsider before a customer gets something that is not what is expected. Just trying to give some friendly advice, if you want it or not its up to you.
NC
ORIGINAL: Mr Cajun Gator
SI, I'm seeing some design flaws, you may want to reconsider before a customer gets something that is not what is expected.trying to
NC
Ok I tried to help, just trying to get things back civil.
FL
Hal,
Proof is in the pudding, apparently you didn’t watch the videos posted above, if you did you would see how the prototype ran. I have already built the laser kit and ran it. It runs like a champ. I agree with Andy, the only flaw I see is the boat stand not being glued.
Yes, I did make a few changes from the prototype to the laser cut kit. But the changes were not on the sponsons or tub, which is the most critical part of the boat. The laser kit performs just as well as the prototype. I'll be posting vids as soon as my camera man is available.
Andy, sorry your thread is getting off track.
FL
Man that thing looks sharp. Now I understand how this hull type is built, after seeing the last picture you posted, it's just like a normal 3-pointer with a piece of cut out plywood on top.
Are there any advantages to this version of a 3-point boat compared to the more common version without the extra piece of plywood?
So with the rudder, are you trying to get the advantage of not only the water but also the air off the prop, like combining to methods of a rudder?
Good luck I hope she runs great
FL
the advantage of the ply on top is to deflect water spray from getting to the prop and it will also help lift the hull out of the water when its still speeding up...similar to how air passing through the tunnel of a catamaran will help lift the hull out of the water...
FL
Andy, I like the paint. Your gonna like this boat!!
I have been working on this design for a while now ( 8 MONTHS) and have it perfected IT. Don't get it confused with other designs that have not even been tested or built. This is a tested and designed kit.
NC
ORIGINAL: 500 lb. koolaid man
Just made two mods on the boat. Changed the radio box lid opening and gave the rudder a break-away. The mod on the lid used materials in the kit and the break away cost me $1.17 extra.
NC
I think the carbon tubes you are looking at are add ons, to help stop some of the warping, of the plywood deck.
I'm sure if I had on of the new laser cut kit ( birch ply ) I would not have had this problem.
FL
I'm new to this, but isn't luan layers of wood pressed together? I may be wrong but that sounds the same as plywood? Does the birch ply hold up better in the humidity than any other ply?
I live Florida and have a problem with Birch plywood warping . I have used birch plywood make my pluges so i can make my molds for my fiberglass airboats. So i know it will warp to in high humidity
NC
ORIGINAL: rcairboat_girl
FL
While Andy was down for the RCAA Meet, we took some video footage. Here is a video of him dialing in his "SI" 3 Pointer. There is more footage that will come also.
[link=http://www.rcuvideos.com/item/YQH1MJ8L52H0Z3X7]Andy's "SI" 3 Pointer[/link]
NC
Great video ! I am not used to seeing Andy back off the throttle in the turns [sm=teeth_smile.gif]
I will hopefully have my SI3 ready for a NC mini meet soon [8D]
NC
Nice to see that you all had a good time at the RCAA meet, did you all have races? If so how did your boat place?
How did my boat place..... the SI three pointer was hard too beat.
So who won...... We all did.
Some of the RCAA guys were talking about comming to a MABA race so the two can have a great time racing. Watcha think!!!!
