RC Airboats Discuss R/C Airboats here!
filling pin holes
Reply
Old 11-08-2007, 05:49 PM
rusty bucket
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default filling pin holes
I'm just now putting epoxy on the bottom of the boat I'm building. Just wondering what everyone uses to fill those crazy little pin holes. I seem to have a over abundance of them when the epoxy dries. Thanks in advance for any replies.
Rustybucket
rusty bucket is offline
Old 11-08-2007, 07:48 PM
asmithnc
asmithnc's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: filling pin holes
The pin holes are caused by air bubbles when mixing the resin. Try this..... A little tip. Lightly pass over the resin with a Propane Torch to draw the bubbles out. Becareful not to over heat...
asmithnc is offline
Old 11-08-2007, 08:25 PM
89ram
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
could stirring the resin slower cause less pin holes? if not, maybe get some autobody filler to fill them.
89ram is offline
Old 11-08-2007, 09:00 PM
Selph-Inflicted
Selph-Inflicted's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Stirring less aggressively will lessen the air bubbles.
Also laying out thinner layers and using a skread to work the resin will work most of that out also.
And as Andy stated, a properly used torch will get rid of those for you.
Selph-Inflicted is offline
Old 11-09-2007, 09:18 AM
TERBObob
My Feedback: (21)
TERBObob's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Another little trick/tip :
When mixing the resin together , warm the resin under your hot water tap and get it warmed up . This way , there is no worries about the torch , or anything else . The resin will get looser , which , in turn will allow the bubbles to flow to the top and wha-la ... no pin holes .
I use marine 2 part epoxy which is VERY thick and this cures that problem ALL the time .
TERBObob is offline
Old 11-14-2007, 02:30 PM
Ron Olson
Ron Olson's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I got this tip from Phil Thomas of RC Marine Designs who builds epoxy-glas hulls. Use ordinary wall spackling thinned slightly to fill the pinholes. You want it thinned to the consistancy of mayonaise.
Ron Olson is offline
Old 11-20-2007, 05:36 PM
dadkins
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I would use litweight body filler (Bondo) I think it would be better to paint over than spackle.
dadkins is offline
