a .61 glow laying around
OH
I have a Fox .61 glow engine laying around from a plane i dont have room to fly. presently im into electric helis but seeing some your the airboats on here has me thinking. What size boat should i look to build around a motor like mine, just some general ideas. I have a 3/4 acre pond on my property that i could play on. I am not looking for major performance really, just mainly something stable to play around with on my pond and from my houseboat. Thanks in advance
MB, CANADA
RE: a .61 glow laying around
The Dumas, Big Swamp Buggy Kit,looks pretty easy to Build..Unless you prefer to scratch Build from Drawings. or even make up your own Drawings/Design..0.610"engine should sizzle along.Those ,Foam Jobbies the Guys are building look pretty good too..Lots of options out there..
OH
I want to do a custom build, i'm thinking a combo of foam and wood. Im in engineering and can do the build, i was just hoping to get some advice on proportions and dimensions, i dont need plans per se just an idea of where to start
OH
TX
That's a question that will bring out a lot of opinions, so here's how I would tackle it.
Start with the largest prop you would use on that motor. Add 3 inches to get the width of the deck on your boat.
Make the length between 1 3/4 and 2 times the width.
Make the hull 2 to 2 1/2 inches deep.
Angle the sides 45 degrees.
Start the rake 1/3 of the length from the bow.
Make the balance point around 1/3 the length fropm the stern.
Most importantly, get vids.
WI
ORIGINAL: D Bronk
OR, you could do like me, with the," Looks`bout right." Style of Engineering..[8D]
MB, CANADA
ORIGINAL: crispyspa
yea...but you seem to have a "knack" for it.
ORIGINAL: D Bronk
LOL!!!
around a 32" long hull and 15" wide should get you where you're going, add that to jasper's detailed description and you're off!
shaun
shaun
OH
i have a pretty good idea in mind thanks to the help from y'all. Have a question in mind. I am planning to make the hull out of foam and then glass it. right now i am thinking of two layers of 1" foam epoxied together, between the foam sheets make a void most of the length and place a peice of plywood(like 1/8" or something) that has grommets i can screw my motor mount into. Will this give me the strength i need to hold my .61?
WI
I see no reason why not. This pic is of a now destroyed hull that I built last year. to hold the 9 LB gasser engine, all it took was a piece of 1/4 " ply epoxied to the foam. It held through the most horrific crashes.LOL
TX
I think putting the ply on top rather than sandwiched will serve you better. The foam between the ply and mounts will get torn up I think.
