Go Back  RCU Forums > RC Boats > RC Airboats
Reload this Page >
bad porpoising please help..
RC Airboats Discuss R/C Airboats here!
Old 03-27-2008, 06:22 PM
nick34
Default bad porpoising please help..
hello again im back readjusted eng mount moved way back man what a diff. it even flies on my grass .. i still had the eng pointed up a few washers but it still hops in the front pretty good to the point where it almost flips but i noticed it does it more when i let of the throttle it will be running smooth then start porpoising a little then i let go of the throttle and it starts hoping really bad what else can i do????
Old 03-28-2008, 12:15 AM
boatman1
boatman1's Avatar
Default RE: bad porpoising please help..
Sounds like you need a bit of weight add to the nose of it
a few oz. in right place may calm it down
if you need more than 6oz. to settle it down , you need to see about
changing the motor angle some more
Hope this helps
Old 03-28-2008, 06:13 AM
Selph-Inflicted
Selph-Inflicted's Avatar
Nick,
Sounds like you may have moved it too far back now. I personally don't like adding weight to the boats. I like to utilize the weight that I have on the boat to make corrections. I would say move the motor forward a little more.
Old 03-28-2008, 06:23 AM
asmithnc
asmithnc's Avatar
I had a big flat bottom with 1.00 and it did the samething. I then added 1 pound to the front and it had no change in the attitude.
Two ideas.... add a water rudder. The extra drag may lessen the hopping. Trim tab will force the front end down causing a better ride.
