Airboats for winter running?
MN
RE: Airboats for winter running?
I would go with coroplast rather than plexi - weighs a LOT less - You may have handling issues with it wanting to only go straight - imagine two huge vertical stabilizers - maybe not though....
Personally I would ditch the wire mesh and part of the aluminum and run er in the open air - make the center support into a carrying handle and most importantly- Keep your apendiges away from the prop.
ON, CANADA
I thought of making the frame smaller but since it's for snow I want everything inside to be contained. True it would look soo much nicer!
I also thought the clear plex would look cool like a display. I have a 1/8 sheet in the garage. I guess I can always try it out
My cages are made from stainless steal tubing 5/16" on the hoops and 1/8" for rungs then it is all MIG welded together, the cages are very strong, in fact I weigh 225lbs, and the cage supports me well. OK to my point, I had a blade break off at the hub, the blade then broke through 1-1/2 rungs. I don't know if it just happen, hit just right or what happen, I do know that when a blade breaks loose, its best to have something there to stop it or at least slow it down some. The wire mesh is a good idea to keep your hands from getting into the prop, the plex-a-glass do not use. It will crack and break from the vibration, taking a chance on a section breaking off and falling into the prop, then you have a sharp projectile flying.
ON, CANADA
ORIGINAL: Mr Cajun Gator
ON, CANADA
First video on ice! Brad (AKA Bradius) was driving it while I filmed. It moves without even using the throttle!!
http://ca.youtube.com/watch?v=7k2a0kNG0T4
Waiting for some good powder now!!
May add some side skis later.
#31
MI
If you are going to be running your boogi board on ice a lot you are going to tare up the bottom . You might want to fashion a piece of corroplast to the bottom . Corroplast is some tuff stuff . It even works well on dirt and blacktop and concrete . Just a thought .
#32
ON, CANADA
ORIGINAL: RS 38-40
#33
MN
Ok - If you do decide to use coroplast on the bottom - which I have with really good results. the best way I have found to bond it to foam or wood is by poking a bunch and I mean hundreds of tiny holes thru one side (the side you put glue on) and then smear a thin layer of gorilla glue on the coroplast and stick it to the hull set the hull right side up on a Glass sheet or a very flat surface and put about 20-30 lbs of weight on it to keep the gorilla glue from expanding and making the bottom less than perfectly flat - then use duct tape to pull the rake and sides up.
#34
NT, CANADA
ORIGINAL: RS 38-40
#35
ON, CANADA
Yup it's a "snow rider" made for the snow and ice so there's a layer of plastic on the bottom. It has ridges so steering is made easier on snow. Before I launch it on a filed of ice I'd like to have skis along the side for more support so it doesn't flip and have gas leak out.
#36
ON, CANADA
Here's another revision!
Some Vids we did today:
http://www.youtube.com/watch?v=iEXIY...e=channel_page
http://www.youtube.com/watch?v=zkTAs...eature=channel
http://www.youtube.com/watch?v=z-0Pn...eature=channel
#38
ON, CANADA
A few questions for the experts:
I use a 14x7 puller.
1. If I chage to a 3 blade all I get it more pulling power but I lose on speed right?
2. Does this happem if I go with a higher pitch as well, like a 14x10?
My rudder is fairly large since it was my first attempt. If I round off the top and bottom instead of the 90 degree you see how would this change the steering? Less or more?
#39
WI
ORIGINAL: SELWA
Your rudder is kinda big, try cutting it shorter (front to back) in 1" increments and test between cuts. When you lose good steering, you've gone too far.
#40
MN
I don't think that would hurt your steering to round off the rudder - and it looks like you could cut some off the back maybe an inch or two without affecting it too much.
#41
Bigger props is not always the best way to go. Its best to find what prop the boat and the engine works best.
Ex: on my 27cc boats I like the 14 x 7 3-blade MAS and it runs great, but I can drop it to the 14 x 6 2-blade APC and the boat is faster. Difference is the engine is developing more HP and RPM with the smaller prop. But I rather the 14 x 7 3-blade because I'm still getting very good speed and it lowers the RPM given the engine a longer life.
Things to look at when testing props
transition from idle to full throttle, does the engine load or becomes sluggish? More than likely to large of a diameter and/or pitch
engine turns lots of rpm's but boat is slow. too small of diameter for the size of boat.
#42
ON, CANADA
Thanks again for the tips guys. We just got a few feet of snow so I have a good test area now. Plus I found a shop about 30 minutes from me that has a good selection of props. [8D][8D]
I think I'll cut down the rudder a few inches and round the top and bottom. I didn't like the huge rudder but it was a good starting point.
Question
Of I were to put a round cage ( Like a 15" cylinder) around the prop would this give me any better performance in terms of better air pulling??
Question
#43
ON, CANADA
Just an update!
I dropped the engine 1.5" and cut down the top another 3" as well as shorten and round off the rudder. I also remove the side skis just to see how it will work for now. It's been far too windy to try it out today. Hopefully tomorrow!!
I may also try a 13.5 or 12" diameter prop since I noticed the edges of the prop I have now overlap the aluminum frame. I assume that this starves some of the airflow. By lowering the diameter and increasing the pitch it may work out. Maybe a 12x10? I'll try a 2 blade before a 3.
Any suggestions?
Any suggestions?
#47
MN
I wouldn't glass the windy - It is already a pretty heavy boat for it's size - also pretty durable, I would do a couple skim coats of epoxy applied with a credit card.
#49
ON, CANADA
ORIGINAL: Scrape
Hey SELWA
That's cool and sounds great.
How about strapping that camera on there and taking us for a ride?
Hey SELWA
That would be very interesting!!!
