If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 8 of 8
  1. #1
    500 lb. koolaid man's Avatar
    Join Date
    May 2006
    Palm Harbor, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Wood for a small electric airboat?
    I'm thinking about building a brushless airboat about the size of a Dumas Lil Swamp Buggy. I'm planning on scaling down the Gator 24" plans. Would regular Tower Hobbies plywood (not birch like Midwest brand but much cheaper) work alright? And what's needed, just 1/16" (with the exception of a 1/8" motor mount), maybe 1/16" and 1/8" (1/8" is 5 ply and 1/16" is 1 ply on tower in case that matters)?
    Thanks.
    \"A penny saved is a penny earned\" -Benjamin Franklin
  2. #2
    Rowboat's Avatar
    Join Date
    Apr 2005
    Sydney, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Wood for a small electric airboat?
    I don't know about towers ply .The ply from the hobbies shop should be ok to use, it would be a good quality wood. Have you considered using balsa wood? It is much lighter than ply. I have built lots of balsa boats with nitro engines and one electric boat. I am not sure how cheap where you are. But why not give it a go.
    Boating is not a matter of life or deth, It is more important than that !!
  3. #3
    Join Date
    Jul 2007
    mpls, MN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    better than balsa use depron. its cheaper stronger and lighter than balsa
  4. #4
    SlashBasher's Avatar
    Join Date
    May 2008
    out bashing
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I used pink insulation foam and sanded it to shape. This is my first airboat but I plan on moving up.this is the cheapest easiest way IMO. Its fast to!
    Attached Thumbnails Attached Thumbnails Click image for larger version.
    4s Slash- mamba max- turnigy 36-57 2600kv- flm adpters and 1/8 buggy badlands- tons of rpm and aluminum upgrades
  5. #5
    Join Date
    May 2006
    Palm Harbor, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    You have the exact motor / esc that I'm going to use, Hobbycity
    Thanks for posting that picture. She looks nice What prop size are you using?
    I'll consider pink foam. Either that or balsa, not sure which yet. Balsa just seems much more "solid" to me.
    I wonder what thickness I will need if I choose balsa, 1/16 for skin, 1/8 for motor stand, and which for the rest?
    Thanks.
  6. #6
    Rowboat's Avatar
    Join Date
    Apr 2005
    Sydney, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I would 1/8 for the skin, the next size up for the engine stand, or use 1/8 ply. Remember that the hull should be sealed with an epoxy coat. The balsa can dint easily it also can be repaired cheap and easily. Use 1/8 for the framing as well. The boat should be sealed inside and out. This will stop any twisting in the hull due to moisture.
    If you had the money you could apply one layer of 3oz fiber cloth to the outside of the hull this makes for a very strong hull and it is still a light weight boat.
    If you use pink foam it is easer to shape and you can glass over the foam as well. I just prefer working with balsa. I can build in the lounge room while watching TV, I can't sand foam.(The wife would kill me)
  7. #7
    Join Date
    May 2008
    out bashing
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: 500 lb. koolaid man
    Thanks.
    Thanks! Im using an 8x3.8 prop on a 2s lipo. I havent tried it on water yet but its really fun on ice!
  8. #8
    Join Date
    May 2006
    Palm Harbor, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks guys. I have all the info I need. Time is now my only enemy College and my signature
    Thanks again.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
