IMPBA,NAMBA and the M.Ab.A
We are currently working with IMPBA in setting up a gas class for the LS airboats. The first IMPBA exhibition race is Feb 7th in Baton Rouge La. e-mail Jeff Neal [email protected] they had a web site nirtoburners.com not real sure if it is up.
The second race is in the works,for the first NAMBA exhibition race, March 6th-8th. [link=http://www.jrcbd.com/attachment.php?attachmentid=24869&d=1233112130]VooDoo Gator Bash[/link]
Hopefully soon we will be working with the NAMBA in setting up a class for the airboats.
Mod edit - removed links
Hal edit- changed links
RE: IMPBA,NAMBA and the M.Ab.A
large scale gasoline. If you see a class called LS27 Mono translate into Large Scale 27cc gasoline engine "V" hull or hull with one wet surface while on plane.
