Aluminum step-hull build thread
FL
I had been wanting to build a new boat for quite sometime now. I already had another hull like the one I just sold and was going to use that until I went to some local races here on the St. Johns. Then I wanted to build something for a different purpose. Drag racing. So I went with a stephull deckover. I knew my motor selection the whole time, just had to change the hull. I will be using a ff240 or a ff320 os engine to keep it with a scale look. The first picture is a step hull and is what my hull is modeled after.
The next pictures are my boat. I started on paper with three different models and picked the one I liked best.
From then I want to the steel yard and got two small sheets of .045 alumium and some angle and started building. The rivits are the smallest fastenal makes and I have already went through 500. I have another 500 coming monday. The last picture is what I did today, got the bottom on but not fully rivited off. I do need help on what to do about eletronics I would like something below deck with a not so noticable lid. Any suggestions? Let me know what yall think and if you have any questions.
WI
RE: Aluminum step-hull build thread
ORIGINAL: DONS BOAT WORKS
The only problem I see is that I think the rivets on the bottom will cause a lot of drag.
Don M.
Don M.
FL
Slick Bottom is also called Frog Spit it's like a polymer bottom, but you roll it on with a roller. I also got the transom on today with the few rivits I had left. I will try to have pics up tonight.
I've been doing a 2 step process on the bottom of my hulls that works well and finish out very slick. Both steps can either be rolled or sprayed on. Working on getting smaller cans for the stuff, then plan to offer it to every one. I will give more information later.
Nice build you have under construction.
FL
I have been looking for a dry box that had a low enough profile that it would fit in the 2 inches I had. Couldn't find one. I will have to make my own. It will be a sheet of alumium raised off the bottom of the boat. I plan on taking allen head bolts and welding them in the up right posistion and letting the plate sit on top of them. This way I could bolt from the underside when I mount servos. Above the step to the top plate will be sealed off as well as the front of the box before the bottom bends up. I have included a picture of this. Any better ideas?
FL
ORIGINAL: asmithnc
SInce your boat has a water brake I now you have been around full sized drag airboats now. Great build.
FL
ORIGINAL: greygoose81
what do you think your final weight will be?
nice build...
nice build...
TX
There aren't a lot of aluminum RC airboats that I've seen and I think a good deal of it is the difficulty most people have working with sheets of it without trashing it or cutting themselves. All that to say nice job with the metal working! You've got some skills.[8D]
FL
ORIGINAL: jasperrc
FL
Caylen17, nice build. I've looked into aluminum, but as others have said, it's not easy to work with and very time consuming. Yours is looking sharp. I live in Pt. St. John and I am trying to get people together in this area to race and have fun. I have raced with the M.AB.A. in La. and in Ocala last month. Had a great time. If you might be interested let me know. I will P.M. you. Dennis
FL
Sorry for not havin any recent pics. I am still working on it everyday, but camera went down. I will post some recent pic tomorrow night.
FL
Got the motor!! Dave from D's Hobbies in Oregon responded to a wanted ad and it worked out great. A new in box ff-320 with manual, tools and whatever else comes with it. I need the motor to mount my steering and throttle cables and put the back deck on. Tomorrow if all goes well I will have the completed hull ready for riggin. I will have pics of the hull and motor tomorrow March 12th.
