RC Airboats Discuss R/C Airboats here!
Cutting 1/8" luan door skins
Reply
Old 02-20-2009, 06:35 PM
toystory_4wd
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Cutting 1/8" luan door skins
I've read (and discovered) how cutting this stuff with a powered saw results in an impressive toothpick collection. I decided to try a different tack- I've been doing my cutting with a #11 Exacto blade for small cuts and curves, and an Olfa rotary cutter against an aluminum framing square for longer straight cuts. The results are nearly laser-cut perfect. In both cases I got the best results with light pressure and multiple passes. While this does work very well, I just want to warn everybody (especially those not familiar with the Olfa) not to press very hard, or try to rush things. I had visions of the cutter jumping the straightedge and severely modifying my fingers!!! [X(]
Just throwin' it out there. Cheers- Chris
toystory_4wd is offline
Old 02-20-2009, 10:29 PM
jasperrc
jasperrc's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Cutting 1/8" luan door skins
I've used the same process except that I used a utility knife against an aluminum straight edge.
I've also had good luck by cutting a little outside the line and then sanding to the line with a belt sander.
jasperrc is offline
Old 02-21-2009, 12:20 AM
500 lb. koolaid man
500 lb. koolaid man's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for the tip I'm considering using door skin in a future project.
500 lb. koolaid man is offline
Old 02-21-2009, 12:46 AM
crispyspa
crispyspa's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Jasper beat me to it.
I laughed out loud when I read this:
crispyspa is offline
Old 02-21-2009, 03:54 AM
jetpack
jetpack's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Get some good old 3" masking tape, the goopy kind and lay it down where your pass will be and lay your lines out on that. Use a fine tooth saw blade and set the blade a little high if using a table saw. The tape will work.
Jig saw, scroll saw, band saw, same thing with the tape, always a fine tooth on that stuff.
jetpack is offline
Reply
Display Modes
