hydraulic controls
FL
RE: hydraulic controls
ORIGINAL: greygoose81
I think in a shock there is an orifice in the piston head. So if you were to try to use a shock you would need to disassemble it, take out the springs, some how plug the orifice and then drill and tap for ports. That’s a lot of effort to try and make it work for something it is not intended to do. Keep the input coming. Here is a quick drawing I made of how I think a RC shock works.
In looking at a few of my spare shocks laying about the bench, they are all externally "spring'd", with nothing but silicone oil inside. The pistons are generally plastic with 2 or 4 small holes to allow the oil to pass thru, the weight of the oil determines how fast or slow the shock is.
I figure some CA on the holes to seal them, and then drill/tap the cap of the shock. There is sometimes a rubber cap/bulb thing that would need to be removed, possibly replaced with an o-ring to promote sealing between the cap and the shock body. If you needed a 2-way ram, you'd tap both cap and someplace in the side to provide twin chambers, and some fuel line below the piston to keep it from passing the fluid port for the lower/bottom chamber.
Shocks are (relatively) cheap, and one could use a large one at the servo to drive 2 smaller ones at the rudders.
When I build my next hull, gas or nitro remains to be selected, but I am planning on testing this out. With a selection from 1/16th to 1/5th scale shocks available, this would be very cool.
FL
Hey greygoose81 how is the hydraulics coming along? Any chance someone could buy a pair of the large cylinders and if so at what price? I would like to set them up on my new big boat. Dennis
These are the cylinders I am working with now. I got side tracked on another project, but I am getting back on it now. I am going to run some tests with these, and if it goes well I will more than likely use them. As soon as I test them I will let you guys know how it went.
#34
KY
you can get it in almost anything i run 40wt in my car shocks and thats way thicker than antifreez though so you would have to try thinner. id ask your lhs
#36
I am starting on a new boat and plain to use the hydraulics cylinders that I know work. I want to go over board on this build to show the possibilities of using hydraulics. I will use them on the rudders and throttle and may add an adjustable trim tap. There are some other things I want to do but I got to keep that down low. Don’t want to give anyone a heads up before the next MABA race.
I am working hard to get it all just right. Tried to use some other cylinder but I’m going to need to do some modifying for them to work. But it is coming along slowly but surly. Here is a pic of the cylinder that I will be using.
#39
FL
It works by having one cylinder being operated by your steering servo and one cylinder being connected to your rudders. When the servo moves the piston on the cylinder hooked to it the fluid flows to the rudder cylinder and moves the rudders. Nice clean system. I am planning on using hydraulics on a BIG r/c airboat of mine. It will be using a McCulough 46cc chain saw engine. I will let you know how it works. I purchased the cylinders from Greygoose81. Dennis
#41
NC
I had an idea to make a small gear pump and let the main engine turn it in a plane. Most of our gasoline engines have a shaft out the back and I thought that would be a way to drive the pump. You really don't need tons of pressure. maybe 100 psi. That should be easy enough to produce with the right lightweight oil. Then you could use a spool valve located anywhere you wanted with a micro servo. The lightweight servos should counter any weight addition from the pump. This is just an idea I have been toying ith for a while.
But from what you are using..Have you tried small air cylinders. They would work fine with lightweight oil. At least I think thet would. Would like to hear how your setup is so I can understand it.
#42
TX
That is my favorite vodkaLOL!! I knew there was somthing about your username I found familiar!!!!
Greygoose vodka would be the stuff to use, but that would shoot up the cost.
#44
FL
You could use the valve from a retractable landing gear system for the control valve. The only problem is it will not be easy to get the exact amount of rudder throw desired. The valve will only be right/left. You will have to move it to neutral. When I was on subs in the NAVY(Never Again Volunteer Yourself) I spent a few months diving and driving. All our controls were hydraulic/ electric. If you turned the helm say 10 degrees the rudder would move that far and stay there till you turned it in any other direction. I wish I could remember how it worked. If I can remember that would be a perfect system for this. If it could be built. Otherwise the two cylinder system is the way to go. Dennis
#45
hey guys this sounds pretty cool. would be a sweet setr up. but dont forget an important fact. hydrolic oil is used because it doesnt compress unlike many others. atf[automatic trans fluid] is one of these fluids and can be obtained in 5 to 10 weight which would work great good luck
#46
oh an after thought, i may have some rams ,hyd cyl. that may work real well hear. when i find them ill post em so you can try them. this should be easy to make up.ill get back
