RC Airboats Discuss R/C Airboats here!
Help with redneck airboat...
Old 01-29-2010, 09:08 AM
alangranvue
alangranvue's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Help with redneck airboat...
Hey guys. I am building a float/boat to attempt to retrieve my deadsticked airplanes. It may not work but I just wanted to give it a shot and figured it would be fun building. Here are some pictures below of it. I am almost finished but being that I built it from balsa, how do I water proof the balsa? What can I coat the wood with so it doesn't swell/rot.
ID:	1367056   Click image for larger version
ID:	1367057   Click image for larger version
ID:	1367058   Click image for larger version
ID:	1367059   Click image for larger version
alangranvue is offline
Old 01-29-2010, 09:17 AM
b16a2sir
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Help with redneck airboat...
30 minute 2 part epoxy seals it up good!
b16a2sir is offline
Old 01-29-2010, 09:22 AM
alangranvue
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Can you just apply it with a brush? If so, what could I put on the brush right after I use it to remove the epoxy?
Old 01-29-2010, 11:12 AM
DJLaPalme
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
To seal the wood I mix my epoxy with denatured alchohol at a 1/3 each ratio( 1/3 resin, 1/3 hardener, and 1/3 alchohol). Use a cheap brush because you won't want to try to clean it out. I don't think you can ever get it real clean. Dennis
DJLaPalme is offline
Old 01-29-2010, 11:22 AM
alangranvue
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
good deal. Thanks for the info guys!
Old 01-29-2010, 01:04 PM
asmithnc
asmithnc's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Just use finishing resin it's thin enough so no need to add alchohol. Brush on and then wipe off....it's that easy.
asmithnc is offline
Old 01-31-2010, 06:56 PM
alangranvue
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
awesome, I tested it out today! it actually works like i had hoped. Thanks for the replies and help guys!! Much appreciated!
Old 02-02-2010, 02:55 AM
jesupslanding
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
mind if i ask y its "redneck"?
jesupslanding is offline
Old 02-02-2010, 08:39 AM
alangranvue
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I get called a redneck quite a bit in my club because of some of the things I "rig up".  The guys call it my Redneck Airboat.
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
