Engine pitch
PA
Engine pitch
When the motor is mounted with prop faceing foward, does the motor have to be on any spcific pitch? Front or rear and how much of a pitch if any?
FL
RE: Engine pitch
Most boats seem to work best with the engine mounted level or close to it. I mount mine level and use washers under the engine mount bolts to adjust the angle as needed. Dennis
FL
RE: Engine pitch
Alot depends on your hull, but my puller seems to like it's front raised a bit, which directs the prop wash down toward the water a little. My theory is that this helps lift the stern a little and keep the bow from slapping as much.
I just use a few washers under the engine.
