EDF Airboat
KS
EDF Airboat
I was wanting to build a Streamline EDF Airboat with a 3.5in 7 blade EDF, powered buy a feigao 12xl on 6s lipo.
First of all is that a safe setup?
What would the speed be like?
What size hull should i make?
Were do i get plans for an Airboat?
I have never built a boat (complety finished one i should say), but how hard is it to build a AirBoat hull.
There are just a few things i want to clear up before i decide to build one.
FL
RE: EDF Airboat
I hate to be the one to break the bad news to you, but, several have tried to build an EDF and as far as I know none of them have worked. Apparently the EDF can't overcome the drag to get up on a plane. Give it a shot. You could be the first. Maybe! Dennis
PA
RE: EDF Airboat
For the same amount of money you spend on the ducted fan, you can get a prop setup with about twice the thrust... plus it won't be an amp hog and your run times will be longer.
NT, CANADA
RE: EDF Airboat
they work but differently from a air propped boat I'm working on one but taking forever. for their size they put out a lot more thrust then people think making most of the edf boats I have seen dive making them un able to plain off. if you plan to build one go with foam and keep it vary light, as well a hydro stile would work best or something without much drag. an edf don't have the low end thrust or acceleration compared to a prop they are geared more for top end speed so if you can get it going without much resistant's it will be faster than a propped boat of the same power plant. if this is your first boat I would not recommend it but if you have the equipment already why not =)
PA
RE: EDF Airboat
ORIGINAL: pinky_d_brain
If it works out, I might just have to make room for another airboat in the shelf!
FL
RE: EDF Airboat
When I said "maybe" on my earlier post, I was not questioning your build talents. I meant I don't know if anyone else has ever made one that works or not. Give it a go and let us know how it is going. Only way to accomplish something is to try. Dennis
PA
RE: EDF Airboat
This is my "dream" setup, something that I would love to try out given the funds. I think your choice to put it in the predator outrigger is an interesting choice. (especially since that particular craft benefits from the lift created by the water-prop). I have built one and once it gets on plane, it needs very little thrust to stay up there. If you keep things light, you will have a very good chance of getting it up on plane... once again, this is all in theory!
My dream setup:
This fan:
www.hobbycity.com/hobbycity/store/uh_viewItem.asp
This motor:
http://www.hobbycity.com/hobbycity/s...idProduct=5158
This ESC:
This battery:
$272... without shipping... one can dream about it... one day.... (I don't know if I would have the balls to go WOTwith that setup though)
BTW, my estimate is that the power setup above hould push a medium-sized gasser hull to its limits.
so, gonggongboy, what are your plans? This is your thread, don't want to hijack it, just throwin' around some ideas.
My dream setup:
This fan:
This motor:
This ESC:
This battery:
RE: EDF Airboat
there's one on ebay. he said its never been on water but I bet it has and just dosent go anywhere
http://cgi.ebay.com/Ducted-Fan-Jet-A...item27b2e38826
