RCU Forums
RCU Forums (http://www.rcuniverse.com/forum/)
-   RC Airboats (http://www.rcuniverse.com/forum/rc-airboats-246/)
-   -   which boat for .61 nitro (http://www.rcuniverse.com/forum/rc-airboats-246/10281059-boat-61-nitro.html)
mrloganstp 01-22-2011 04:24 PM
hi i currently have zero experience with air boats but have a os max 61v nitro motor which i am relay keen to make an air boat with. from what i have found a dumas big swamp buggy or one of the selph inflicted hydros look like options but i would appreciate some expert advice.
thanks logan.
71dartswinger 01-22-2011 04:54 PM
RE: which boat for .61 nitro
i have had both and sold my big swamp buggy and kept the SI 3
you can run grass/snow with the BSB as it has air rudders
SI 3 is a lot less work to build than BSB
crispyspa 01-22-2011 06:17 PM
I am kind of partial to the SI hydros....I have four of them. LOL
jasperrc 01-22-2011 07:05 PM
It kind of depends on what you want from your boat.
I've never built a BSB but I've seen quite a few and driven one. They seem to be tricky but fun to drive. A .61 or so is probably the biggest motor I've seen on one. I have heard the build instructions and some of the less important parts in the kits leave something to be desired.
I have one SI. It's very fast and a lot of fun to drive, but I do flip it occasionally (as with ALL of my boats;)). It was well documented and simple to build.
mrloganstp 01-22-2011 08:03 PM
thanks. do any of you know if its possible to put an air rudder on an si if so would it be any good.
sorry if this is a stupid question.
1QwkSport2.5r 01-22-2011 09:14 PM
Quote:
ORIGINAL: mrloganstp
I would think so. You could PM Chris, the guy that designed/sells the kits. He seems like a good guy that might work with ya on something custom, I'd bet. Here on RCU he's "Selph Inflicted"
A good air rudder setup is said to be nearly as effective as a wet rudder on water if the guy driving knows what he's doing.
mrloganstp 01-23-2011 02:58 AM
thanks. i will do that.
Selph-Inflicted 01-23-2011 06:58 AM
Mrloganstp,
On the SI3, on water, air rudders will not have enough force to turn the boat once its on plane. It will turn it at low speeds but the faster you go, the less efficient it becomes.
I have seen an individual with air rudders running on snow. It did very well.
Water rudder for water running; air rudders will work out of water.
mrloganstp 01-23-2011 01:45 PM
thanks. i will probably be ordering one of your kits ounce i have finished my current project. are there any problems with shipping to new zealand?
Selph-Inflicted 01-23-2011 02:43 PM
Give me your postal code and I will get you a shipping quote. Due to respect for RCU's forum policy, any business inquiry should be made by emailing me.
dadkins 01-24-2011 03:19 PM
I have a BSB with a .40 fast enough on snow/ice, not enough motor for water. The .61 ought to get it going pretty good.
