3rd boat. flat deck 3-point hydro
3 Attachment(s)
I'm calling this operation:speed or bust.
Building this to be silly fast, so I'm using my Thunder Tiger .46 Pro on a Jettstream to power it. 3/16" birch 5-ply plywood, and some 1/8" birch plywood for the sponson/tub skin. 14" wide, 20" overall length. Sponsons are 2"w X 2"h X 9" overall length. Tub is 4"w X 17.5" X 1.5" deep at transom I mocked up 1 hull but deemed it too big for the .46 - It was 18"w x 24" l so I made a smaller one. here's the two side by side: Attachment 2237046 This is where I'm at right now; The foam is only temporary, but gives an idea of size since I dont have the sponsons cut from the plywood yet. As pictured with the foam, The hull weighs 1 pound 9 1/4oz. Its one ounce less without the foam. I'm hoping for less than 4lbs RTR, but we'll see. Going cheap on this one. Attachment 2237047 Attachment 2237048 I should have the sponsons made today and get everything sanded and glued together. I have some mods to make to the engine stand, but I hope to be ready to glue later today. |
RE: 3rd boat. flat deck 3-point hydro
I got mine in Depron ( 6mm ). I laid 1/32 ply on the top for strenght. The bottom of sponsons has 1/32 ply and the bottom of tub is also 1/32 ply. I used thinned epoxy on the ply for waterproofing. I have no water rudder but made an airrudder and used piano wire from servo to airrudder.. I haven't had it out as the hot weather, storms and rain and now moss. Always something. I sand the depron and used latex house paint which they say doesn't eat foam, wait and see.
ORIGINAL: Mikeup I got mine in Depron ( 6mm ). I laid 1/32 ply on the top for strenght. The bottom of sponsons has 1/32 ply and the bottom of tub is also 1/32 ply. I used thinned epoxy on the ply for waterproofing. I have no water rudder but made an airrudder and used piano wire from servo to airrudder.. I haven't had it out as the hot weather , storms and rain and now moss. Always something. I sand the depron and used latex house paint which they say doesn't eat foam, wait and see. This boat is water only. I think its an injustice to run a hydro on land. I'll be happy with 50mph on the water but I wont know for awhile. I think I'm on-par with coming in under-weight. |
Getting closer to assembling it. I still have to make the servo mounts and run the control cables but its just about ready for epoxy. Without the sponson/tub skin on, the hull is about 2lbs. This thing should scoot pretty good with my TT .46, that is if it doesnt sink.
http://i153.photobucket.com/albums/s...IMG_0051-2.jpg |
Looks great! Tie a balloon to the top, won't sink,LOL!
ORIGINAL: Mikeup Looks great! Tie a balloon to the top, won't sink,LOL! |
How about contacting Self-Inflicted or even looking at his site and info he has typed cause you've put your heart into this project. You can't stop now, i said so,LOL!! ?, are you by any chance going to use pink foam inside the sponsons and cover with 1/32 ply? Why i ask is, years ago i built a 25" Cat of Jay Turner and used pink foam inside sponsons with 1/32 ply and worked great. That's when nimH were in play and added weight but i was a novice and only one boat site around at the time. Trial and error and just reading everything available to gain knowledge. Well, have a good day. BTW, Jays sponsons were 25" long and 2 1/2" deep and wide.
ORIGINAL: Mikeup How about contacting Self-Inflicted or even looking at his site and info he has typed cause you've put your heart into this project. You can't stop now, i said so,LOL!! ?, are you by any chance going to use pink foam inside the sponsons and cover with 1/32 ply? Why i ask is, years ago i built a 25'' Cat of Jay Turner and used pink foam inside sponsons with 1/32 ply and worked great. That's when nimH were in play and added weight but i was a novice and only one boat site around at the time. Trial and error and just reading everything available to gain knowledge. Well, have a good day. BTW, Jays sponsons were 25'' long and 2 1/2'' deep and wide. I'm going to add 1/2" balsa strips for skin support in the sponsons and tub. I have to make modifications to the radio box to fit my hitec 645 servos, battery pack and Rx. The 1/8" plywood I have wont make the bends necessary on the sponsons so 1/32" is the ticket. I'll have new pics up later today. |
Sounds good!
Got a good chunk of the hull epoxied together. Servo mounts are done, radio box is halfway glued. Engine mount/center tub is curing right now. Once its cured, I'll mount the servos to run the control cables. Since I'm using Hitec high speed 645mg servos I had to enlarge the radio box a little bit to fit the big servos. I have had really good luck with these servos, So I'm slowly collecting a pair at a time for all of my cars (steering) and my airboats.
New pics will be up later. Off to the hobby shop for some chunks of balsa, thicker fiber cloth, and a few other misc. items to finish this one. I am really hoping I can get it on the water to test next weekend. |
Getting there...
http://i153.photobucket.com/albums/s...R/IMG_0060.jpg |
Picture of Depron
1 Attachment(s)
ORIGINAL: Mikeup Oops! I hope the photo shows up now. For now, I'm gonna keep building hulls for my TT .46 until I get to 50mph or better. The TT is the fastest turning engine I have right now. |
I like the Minnesota cut-outs on each side of the motor stand. BTW- i'll be reading the postings on your progress. I'll be in and out as i have lattice to put around deck and finish a Mono called Arpro 1, i completely revamped it.
ORIGINAL: Mikeup I like the Minnesota cut-outs on each side of the motor stand. BTW- i'll be reading the postings on your progress. I'll be in and out as i have lattice to put around deck and finish a Mono called Arpro 1, i completely revamped it. Got the servos mounted, and have the cables ran the way I like. I dorked it and ended up breaking one of the clevises so I have to go pick up a pack of them tomorrow. http://i153.photobucket.com/albums/s...R/IMG_0062.jpg My own rudder creation. I used parts from an Aquacraft rudder assembly, and a couple pieces of brass. I made a similar rudder for my flatbottom and it works pretty well. http://i153.photobucket.com/albums/s...IMG_0064-2.jpg Here's the bottom view with the servos mounted. http://i153.photobucket.com/albums/s...IMG_0066-2.jpg |
I love Minnesota. It might get cold and snow, but its like no other place on earth. . |
This is going to be a mean machine ! :) Bring it on!
ORIGINAL: Got RPM I love Minnesota. It might get cold and snow, but its like no other place on earth. . Looking forward to posting videos of this little bugger running. Hopefully it runs better than my last hydro build. ORIGINAL: Altered1 This is going to be a mean machine ! :) Bring it on! I am waiting to hear back on another engine - a SuperTigre S45 ringed. If I get it, I'll have another engine to build for...... |
Inside mating surfaces are glassed. I used 2oz cloth and Pacer Z-Poxy finishing resin to do the work. I didnt glass the entire inside because I'm trying to stay weight conscious. All I was really shooting for is a little extra strength and to keep the inside watertight. Next I'll add some balsa strips to the inside edges of the tub and sponsons for skin support. Once thats in, I'll skin it. I want to give the resin overnight at the least to cure before I sand it and put the balsa in.
Here's a pic.. http://i153.photobucket.com/albums/s...R/IMG_0339.jpg |
Almost done.. All thats left is mount the engine and fuel tank, antenna and radio switch, and skin the tub/sponsons.
http://i153.photobucket.com/albums/s...R/IMG_0342.jpg I added a little "flair" with some American Cherry strips on the outside of the radio box and engine stand. This brings the wood specie count up to 3.. Once the skin is on, I'll start getting some polyurethane on it. Hoping to do some testing over the Labor Day weekend. http://i153.photobucket.com/albums/s...R/IMG_0345.jpg |
More pics of the progress. Just need to install the fuel tank and solder the cables and I'm done. Well, I have to seal it up with a few coats of finish but otherwise this is RTR. as pictured minus the fuel tank and fuel its RTR and weighs 4lb7oz. A bit heavier than I anticipated but it should still run out better than my Rigger. The sponsons are a bit oversize from my original plan, 1/2" wider and 1/2" taller. I think its gonna rip pretty decent. Engine is turning a 9x7 apc at 16,550rpm or so, and with another gallon of fuel it might see 17,000rpm. Got a few mods in order to free up another 1000rpm but that'll have to wait til winter.. I'm ready for some fun!
p.s. Dont mind the cat... she wouldn't leave me alone. [>:] http://i153.photobucket.com/albums/s...IMG_0068-1.jpg http://i153.photobucket.com/albums/s...IMG_0070-1.jpg http://i153.photobucket.com/albums/s...IMG_0072-1.jpg I left everything loose so I can pull it apart to finish it which I'll start tomorrow. I figure if I can get two coats on it a day for the next 4 days it should be good enough to tear it up Saturday. The finish I'm using for the last 3-4 coats will leave a nice flat finish which is pretty slick too. I am hoping to be seeing 45mph or better but would be happy to get a speed that'll actually register on the gps, and not have the gps laugh at me. (not like my rigger which ... goes 1.63mph.) anyway.. I'll have pics with finish down in a couple days. |
Don't mind the cat.LOL! Here's something that's funny. We have cats and we just put 2 sisters asleep at 19 years of age. Well , wife went to ARL and saw this white cat and come to find out it was raised by a man put he gave up and ARL got it. Well i was laying in recliner and up jumps LILLY and lays on my chest and touchs lips and marks my nose and fllows me all over. Ok, i was working on a boat and up she comes and puts both front paws in boat and looks at me as to say , lets get it done.I about fell off stool laughing so hard, i about split a gut. When i get busy, and really don't want her around like gluing or soldering in progress, i start the drill and she's gone. Sounds mean but burning hair doesn't cut it and epoxy in cats hair or paws doesn't help. Man it looks great!
ORIGINAL: Mikeup Don't mind the cat.LOL! Here's something that's funny. We have cats and we just put 2 sisters asleep at 19 years of age. Well , wife went to ARL and saw this white cat and come to find out it was raised by a man put he gave up and ARL got it. Well i was laying in recliner and up jumps LILLY and lays on my chest and touchs lips and marks my nose and fllows me all over. Ok, i was working on a boat and up she comes and puts both front paws in boat and looks at me as to say , lets get it done.I about fell off stool laughing so hard, i about split a gut. When i get busy, and really don't want her around like gluing or soldering in progress, i start the drill and she's gone. Sounds mean but burning hair doesn't cut it and epoxy in cats hair or paws doesn't help. Man it looks great! |
Great, i sand the bottom with 2000 wet/dry black sandpaper with water and sand lenghtwise and do make it slick. I just dip paper in a cup of waterand sand and dry with a towel. Man it sure does look nice. Now if you look close at the last picture of bottom, it looks like its ready to burn water. Just got that LOOK>
ORIGINAL: Mikeup Great, i sand the bottom with 2000 wet/dry black sandpaper with water and sand lenghtwise and do make it slick. I just dip paper in a cup of water and sand and dry with a towel. Man it sure does look nice. Now if you look close at the last picture of bottom, it looks like its ready to burn water. Just got that LOOK> Now that I have some finish on it, the colors really pop now. The cherry and and antique maple looks really sharp against the birch. This boat I kept all of the edges pretty sharp. The only taper is on the rake of the tub and sponsons. The trailing edges of the tub (transom) and sponsons all have sharp edges on the bottom. I canted the trailing edge of my sponsons on the outrigger I built, but I dont know if that has any hindrance on performance since the engine doesnt make enough power to get the heavy rigger on plane. I think that one might need a .61 that'll turn some better rpms than the .46 can do. I tested all of the radio functions before final tear-down and everything is adjusted to work decent first run. I only worry if the engine is too heavy and sinks the back end too much. Once I get a few coats on it I'll float it in the bath tub and see where it sits. I'll probably post new pictures then. |
Albeit a few minor servo adjustments, this thing is RTR. I only put 5 coats of clear polyurethane on it.. It could probably use more but since I dont even know if its going to run I didnt want to waste more time and add more weight. I didnt have a chance to weigh it, I'll do that tomorrow.
http://i153.photobucket.com/albums/s...IMG_0073-1.jpg http://i153.photobucket.com/albums/s...IMG_0074-2.jpg http://i153.photobucket.com/albums/s...IMG_0075-2.jpg |
Pretty sharp!!!!!!!!
ORIGINAL: Mikeup Pretty sharp!!!!!!!! |
I hadn't posted the results of my initial test - FAIL. Through a twist of fate, I sanded the marks off on the engine plate of where I wanted to position the engine and forgot about the whole CG balance thing. Long story short - engine too far forward. nosedive. flip over cartwheel style. Made some adjustements to the engine stand, added styrofoam under the fuel tank shelf for a little extra floatation and the reslts so far are much better. She floats on her own, and the transom sits higher though still under water when sitting still. I tested the boat in the grass again with the engine shifted back and I'm much happier. Before, the back of the boat would lift off the ground when under power, now she scoots level and much easier I might add. I might try testing it out at the pond later today if I get time.
New pictures: This is actually the rudder blade from the flatbottom that I modified a little bit. The solder joint between the rudder shaft and the blade was about 1 1/4" long, which made the boat "dance" side-to-side so I shortened the joint to 1/4"-3/8" instead. I already made this mod to the blade on the SICopy. http://i153.photobucket.com/albums/s...R/IMG_0347.jpg http://i153.photobucket.com/albums/s...R/IMG_0348.jpg The rudder on the boat. (I am going to put a different rudder on this thing mounted higher when I can afford a speedmaster. rudder..) I used a nylon screw in the rudder bracket for a break-away. http://i153.photobucket.com/albums/s...R/IMG_0353.jpg Full Frontal http://i153.photobucket.com/albums/s...R/IMG_0351.jpg I need to find a tiny Minnesota Wild hockey sticker to put under the Minnesota cutout.. :lol: http://i153.photobucket.com/albums/s...R/IMG_0350.jpg I don't normally like stickers on my rides, but I couldn't help these two.. http://i153.photobucket.com/albums/s...R/IMG_0352.jpg A sort-of bottom picture http://i153.photobucket.com/albums/s...R/IMG_0356.jpg Engine/Fuel Pump. (I added a return line because the regulator on the pump couldn't be dialed back enough to prevent the engine from flooding. Added benefit is the mixture doesnt change much from full tank to empty tank except for air bubbles at very low fuel levels. ) http://i153.photobucket.com/albums/s...R/IMG_0349.jpg http://i153.photobucket.com/albums/s...R/IMG_0354.jpg This engine is a little picky on fuel tank placement. I could probably get the engine to run fine without the pump and keep the tank below but I like the more consistent fuel mixture. I need to replace the O-rings on the Low speed needle valve before I re-test it, The low end and midrange was a little temperamental the other day. |
tim...just studying your set up for a 3 point hydro...i am about to embark on this type of airboat myself...i have a tt60..what length and width would you suggest..looking at your hull size i was thinking of 18 x 24 ..keeping in mind the kit of selph is 29" long..i alsowish to make the engine mount slide back and forth so i can adjust the cg .. i think that is very importent i have a big swamp buggy and i cant adjust the cg without putting a heap of lead on it...it drags its rear end along puts the rudder mount under water and that slows it down to much...your thoughts much appreciated...bob
ORIGINAL: noisy tim...just studying your set up for a 3 point hydro...i am about to embark on this type of airboat myself...i have a tt60..what length and width would you suggest..looking at your hull size i was thinking of 18 x 24 ..keeping in mind the kit of selph is 29'' long..i alsowish to make the engine mount slide back and forth so i can adjust the cg .. i think that is very importent i have a big swamp buggy and i cant adjust the cg without putting a heap of lead on it...it drags its rear end along puts the rudder mount under water and that slows it down to much...your thoughts much appreciated...bob I have a BSB now as well, mine being extremely bow heavy. It needs to be torn down and rebuilt. |
I decided to dust this thing off and tear it down to rebuild it so it will float, and maybe even run yet this year. Its been on the shelf while I run the snot out of my Kamikaze's.
Tore the skin off the bottom to make the center tub deeper, to aid in floatation. 1/32" plywood removed: http://i153.photobucket.com/albums/s...R/DSCN0695.jpg Balsa stringers added, making the transom 3/4" deeper than it was before, with a lighter taper to the bow. http://i153.photobucket.com/albums/s...R/DSCN0697.jpg Stringers glued on, and bulkhead spacers added, all balsa. http://i153.photobucket.com/albums/s...R/DSCN0699.jpg New Keel skin, made myself from 3/4" American Black Cherry. 4 strips 3/4" wide, 1 strip 15/16" wide. I used 4 small strips of cherry and epoxied them to the 5 strips to make one sheet out of it. http://i153.photobucket.com/albums/s...R/DSCN0704.jpg The skin strips are 1/32" thick and the 4 support strips are 1/16" thick http://i153.photobucket.com/albums/s...R/DSCN0705.jpg http://i153.photobucket.com/albums/s...R/DSCN0706.jpg Waiting for the epoxy to cure, and I'll upload pictures of the skin on the hull. |
Bottom skin is on and curing. Couple pics of the modification. The outside of the tub will get a thin skin to cover and seal the balsa.
http://i153.photobucket.com/albums/s...R/DSCN0707.jpg http://i153.photobucket.com/albums/s...R/DSCN0708.jpg http://i153.photobucket.com/albums/s...R/DSCN0709.jpg |
Here is the bottom skin and the little skirt sort of thing I used to cover the balsa. I just used a leftover strip of cherry.
http://i153.photobucket.com/albums/s...R/DSCN0711.jpg |
tim...good to catch up with you...i am also well under way with a small 3 point...i am very happy at the moment..the only real change i made was i inverted my tt46pro and made my eng tower to slide back and forth so i could adjust the cg o the boat...i have a 31inch dumas swamp buggy..i had a 60tt on it and it went great..i put a tt90 on and it went very well but it did go with its nose in the air...that kit has no provision to move the eng tower to change the cg...i bought the 60 pland of ceph and hope to start the large size soon..but i wish to try the small one first..lookin for anty problems..i have a boating friend who is into hydro racing big time( not air boats) and he has been helping me...i will put up some pics soon as i get organized..i have been away for a whle ..now its time to get back into it....bob
ORIGINAL: noisy tim...good to catch up with you...i am also well under way with a small 3 point...i am very happy at the moment..the only real change i made was i inverted my tt46pro and made my eng tower to slide back and forth so i could adjust the cg o the boat...i have a 31inch dumas swamp buggy..i had a 60tt on it and it went great..i put a tt90 on and it went very well but it did go with its nose in the air...that kit has no provision to move the eng tower to change the cg...i bought the 60 pland of ceph and hope to start the large size soon..but i wish to try the small one first..lookin for anty problems..i have a boating friend who is into hydro racing big time( not air boats) and he has been helping me...i will put up some pics soon as i get organized..i have been away for a whle ..now its time to get back into it....bob I'm going to test float my 3-pointer tonight. I'm really hoping I don't have to chop the engine stand down to save weight, but I will if needed. The stern sank some before, and in some of the update pics above, you can probably see why. If it floats on its own well, I'll pile weight on until the transom drops below the water line to see how big an engine I can run on it. Hoping the Enya 30ss works just right. |
Some more progress on my failed 3-pointer... Cut the old engine stand off and made a new one to mount in its place. The new one is a couple ounces lighter and has a small amount of adjustability added to move the engine fore or aft a little if needed.
Bottom skin with 2 coats of resin and 2oz cloth, and polyurethane on top for a smooth and slick finish. http://i153.photobucket.com/albums/s...R/DSCN0715.jpg New engine stand, with Enya 30SS mounted up. http://i153.photobucket.com/albums/s...R/DSCN0714.jpg |
Love the timber work mate, keep the pics. coming!
ORIGINAL: Ozpulse Love the timber work mate, keep the pics. coming! More pictures will come later. |
