RCU Forums
RCU Forums (http://www.rcuniverse.com/forum/)
-   RC Airboats (http://www.rcuniverse.com/forum/rc-airboats-246/)
-   -   Wood sealer/filler (http://www.rcuniverse.com/forum/rc-airboats-246/8840519-wood-sealer-filler.html)
rchamburger 06-10-2009 04:30 AM
Wood sealer/filler
Is it OK to use wood sealer or putty on bad joints an gaps and then epoxy over them or should I fill gaps with something else??
Thanks in advance!http://www.rcuniverse.com/forum/js/f...ular_smile.gif</p>
Rowboat 06-10-2009 04:44 AM
RE: Wood sealer/filler
It is ok to use wood fillers as long as they don't react with the epoxy coating.
I would stay away from water baced wood fillers. I like to use a filler called Plasti bond, it is water proof. Some other fillers like car bog will go soft when in contact with water.</p>
Mr Cajun Gator 06-10-2009 07:53 AM
would be better to use fiber-glass cloth and epoxy, or chop fiber-glass and epoxy.
