RCU Forums
RCU Forums (http://www.rcuniverse.com/forum/)
-   RC Airboats (http://www.rcuniverse.com/forum/rc-airboats-246/)
-   -   what size boat (http://www.rcuniverse.com/forum/rc-airboats-246/9766795-what-size-boat.html)
noisy 05-29-2010 03:29 AM
what size boat
have been given a set of plans for a flat bottom air boat..but its only 24 inches long...i want to blow them up to a size to take a thunder tiger 61....what length......width.... and thickness ( depth.).....do you think i should build to...all suggestions welcome...i know you guys have built these before...help please....bob
RS 38-40 05-29-2010 07:22 AM
RE: what size boat
Make the deck about 2 inches wider than the prop you are going to use . When you scale the plans up let the other dimensions come out as they may . It usually ends up that the lenght is a little more than twice the width .
DJLaPalme 05-29-2010 09:36 PM
RE: what size boat
I would go aprox. 34"-36" long by 17"-18" wide. I would make a closed deck aprox. 1 1/2"- 2" above the bottom of the hull filled with styrofoam or some other floatation material. Any smaller and you will have a wingless airplane not an airboat unless it weights out like a brick. JMOA. Dennis
