RC Boats General Discussion Discuss general rc boating topics here.
traxxas villain ex slower this year - why?
Reply
Old 05-26-2011, 04:30 AM
gregjet
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default traxxas villain ex slower this year - why?
hi
new to this forum
need suggestions
okay, i am a newer rc boat hobbyist
got a traxxas villain ex last year and the traxxas ez peak charger
wow, alot of fun, boat WAS fast each and every one of the 10 times i took it to the various ponds
near the end of last year and now the boat sounds fast, fully charged, motors, props working good {i think}, butdoesnt have the zip that it previously had
so, thru suggestions i got new 7.2 volt, 3000mah batteries and still the traxxas villain doesnt have the zip it once had
any suggestions ?
how can i get the speed back for this boat ?
should i replace the motors?
gregjet is offline
Old 05-26-2011, 09:57 AM
Tombsy
Tombsy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: traxxas villain ex slower this year - why?
Do you have water cooling? If not the motors may have gotten hot and the magnets lost some zip. You could try a couple new motors I've seen them for under $20.
I would definately add the cooling if you don't have it, I used two pickups on the transom to cool the motors seperately.
Keep the driveline lubed and there are bushings on each end of the motors that you can give a drop of oil.
You can run 7 cell packs (8.4v) that will give you extra speed. The hump style packs will just barely fit.
Tombsy is offline
Old 05-26-2011, 10:57 AM
Angel727
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have one that I'm selling for parts. The esc does not go forward but reverse ok. Motors have water cooling kit. Plus I have 4 sets of batteries that will include free. As is asking $100.00 obo plus shipping.
Angel
Angel727 is offline
Old 05-27-2011, 12:56 AM
ROMA-F1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
YOU CAN BUY THE BATTERY FROM [ WWW.TOWER HOBBIES.COM] 6-cell NiMH 8.5 VOLT YOU CAN GO BERY FAST,GOOD LUCK
ID:	1615159   Click image for larger version
ROMA-F1 is offline
Old 05-27-2011, 04:03 AM
gregjet
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
thanx
still open for more suggestions to get this boat back to the power it had, appreciate any and all, thanx again
yes i do have the water cooling
pretty sure i am good with the batteries, for now, may do the more powerful ones later
thinking the 2 motor replacement is worth a try, and at around 20 each sounds okay
again, the original motors sound powerful
hoping the motor replacement is fairly easy and straightforward, meaning no special knowledge or tools to do it
gregjet is offline
Old 05-27-2011, 08:08 AM
doby
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
What kind of "new" batteries did you get....don't say Venom....
doby is offline
Old 05-27-2011, 09:33 AM
gregjet
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
tenergy from the battery superstore on amazon
7.2 v  3000mah
also had to get the connectors from  maj hobbies for these new batteries
gregjet is offline
Old 05-30-2011, 03:42 AM
gregjet
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
[img]1585[/img]
ordered 2 traxxas titan marine 550 motors - 38$ total shipped to me from amazon.com
they look the same as the traxxas villain ex has in it now
gonna go to youtube to see if i can get tips on installing them
still need any help anyone can offer on this project
gregjet is offline
Old 05-30-2011, 05:29 PM
DONS BOAT WORKS
DONS BOAT WORKS's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Did you grease the shafts.
DONS BOAT WORKS is offline
Old 05-31-2011, 06:35 AM
Tombsy
Tombsy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If you have soldered battery connectors you shouldn't have any trouble with the motor connections. Pre-tin everything and use flux. One motor spins the opposite way so it's connections are reversed. You can always go up a tooth or two on your motor pinions for a bit more speed if your motor temps are okay. Are you using the silicone oil in the nipple's for the driveline or something else to lube them?
Tombsy is offline
Old 06-09-2011, 05:44 AM
gregjet
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
okay
2 motors are in !
picked up a soldering iron and tin
need to get some kind of lube
guess just unscrew the motors out, lube new shafts, pre tin electrical connections, insert new motors keeping an eye on polarity for new electrical connection
anything else ?
will do all this soon
gregjet is offline
Old 06-09-2011, 06:13 AM
Tombsy
Tombsy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You will need to take the old pinion gears off the motors and reinstall them on the new motors use a little blue loctite on the set screws.
Use a piece of paper between the gears to set the gear mesh.
The lube that Traxxas supplies is just silicone oil like they use for shock fluid on rc cars it just squirts in through the nipple by the gear cover.
Tombsy is offline
Old 06-09-2011, 08:22 AM
Team Tekin
Team Tekin's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have put new motors in my Villain EX every year. Just finished a complete rebuild on mine actually, it was in pretty shaggy shape after last summer. Replaced all my cooling lines, new Titans, new driveshaft bushings. I have plenty of fun with this boat in stock form, aside from an RX8 and 4S lipo powering it.
Team Tekin is offline
Old 06-10-2011, 10:30 AM
gregjet
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
okay
thanx to all, especially tombsy
all input, suggestions, relaed experiences appreciated
anyone reading, please chime in
taking motors out now
7 screws removed, one to go
yeah, lets do this !
gregjet is offline
Old 06-14-2011, 05:04 AM
gregjet
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
okay
cant get the gear pinions off the motors to reuse on new motors
1.5 mm hex bit is the correct tool but it wont remove the set screws on either pinion, loose, not a snug tight fit to loosen
may just get a couple new gear pinions from either traxxas or a hobby shop
gregjet is offline
Reply
Display Modes
