where can i get
where can i get
hi boaters where can i find a pump for a jet boat or plans to build a jetboat pump. the jet boat would be different to run and alot of fun i belive..thank you rick
RE: where can i get
Depends on what motor you are wishing to use...
[link=http://www.graupner.de/en/products/b5d08e81-ce25-4ebd-9370-6193af870648/2347/product.aspx]Graupner[/link]
[link=http://www.jettec.co.nz/]Jettec[/link]
[link=http://shop.mhz-powerboats.com/category-11/category-22/]MHZ[/link]
[link=http://www.jet-drive.de/index.php?lang=en]KMB[/link]
RE: where can i get
Wow, I just checked Jettech and their jet drive lists for $849! That's a little high for a plastic pump. I noticed they don't say what size the impeller is. There are also 19mm jet drives available on ebay now for about $25 For the NQD 757 (a copy of the Graupner minijet) and the replacement (13mm) pump for the Proboat recovery decoy costs a little less from any Proboat supplier.
RE: where can i get
The Jettec drive is currently probably the best drive available. Whilst the body is composite the rest isn't.
Check out [link=http://www.rcuniverse.com/forum/m_9361615/tm.htm]this thread.[/link] There is also a [link=http://modeljetboat.com/forum/]jet boat forum.[/link]
RE: where can i get
ORIGINAL: w3bby
