View Poll Results: Would you like to see a Bro******** e-book published
Yes - that would be great !
17
73.91%
Not particularly
6
26.09%
Voters: 23. You may not vote on this poll
Bro rc Surfer Custom Boards
#976
And that's a WRAP !
36' boards boxed ready to be shipped to the UK !.....
Once again - big thanks to Geoff for pushing me to build /develop the 36"s ......thanks to those who have shared the journey with us along the way - it's always fun sharing the rc Surfing STOKE ! in or out of the water .....it may seem like I share 'so much info' - yet! - for myself I still feel like I am only sharing what happens on the surface - look forward to getting started with my very own 36"CrackerJack !.....
#977
From surfing the CrackerJack I have experienced - to set up the ideal weight for the surf conditions I add 200g's of lead into the POD around the CG position...keeps the board in the water and improves righting process ...mixture of shotgun shot lead pellets and epoxy.
#978
Can't get more authentic than Neoprene and Lycra .. 28" CrackerJack Bro kitted out with the rash vest....thanks to Lisa-Marie's great tailoring skills
#980
Is it RIGHT-ing ?.....testing for correct righting / position of the surfer dude before permanently bonding it to the hatch cover
Bro dude stands 36cm's (14.5"s) tall from hatch cover - weighs 2.5 kg's Ready to surf - packed with a 4s ( 5000mAh) Lipo
http://youtu.be/gFT9dmOYZ_o
#983
Hi Dom,
Thanks for posting the video and all the build pictures. I learned many crafty tricks
CrackerJack handles and carves amazing!
Please, don´t forget to add the servo, the additional 5/4 mm shaft couppler. Also, would you mind throwing in the prop teflon washer and some extra black plastic nut for the hatch?
Any comments, please send me an email.
More than happy with the board and dealing with YPC
Christian.
Christian.
#985
Howzit Christian .....thank you !.... for the order !.....Glad that you have enjoyed and benefited from the build process. Additional components will be supplied.....as well as a board stand.
Cant say I tire of sharing the stoke !...... next two CrackerJacks coming up are for OZ - then something different again for the US - hopefully get to build my 36" ....in-between it all .....
Picture of electric layout as requested.....
#986
A 2s Set up for the YOUNGér rc Surfers - more than fast enough - within their control .....can later run 3s set up..
Combo - 3650/2930kv - 120A esc - 2s -5000mAh - 27 mm prop ( plastic) 7 degree timing .....
http://youtu.be/9m0mB2VJ3Lg
#987
Weekend activities !
Jensen strutting his stuff with his 2s set up - 3650/2930kv - 27mm prop - both he and the board showed great promise .....real fun to share the rc Surfing STOKE with the boys !
https://www.youtube.com/watch?v=G4M48jkP9vI Decided to 'sea'how a bigger / lower kv motor would perform in the board with a bigger prop !
Small grinding modification to motor well area by enlarging the space ...
3674 / 1650 - 34 mm s/s prop - felt positively 'different'not ready to say it is any better - run times were only about 10% longer ......
https://www.youtube.com/watch?v=uDKzzkhgz3w
#988
SHIPPING !
Packaging a Bro rc Surfer to survive the long journey over land and sea is as much a Technical design measure as when building the board.
The idea is to float (suspend) the board within the box to ensure no direct impact or load pressure, yet - to keep the box volume and weight
as low as possible to keep the shipping cost within reason - the board is repackaged within foam - bubble plastic - corrugated hardboard - then -
placed within a corrugated rolled tube which is glued in position at either end, allowing for clearance all round.......
Size 80 x 30 x 30 cm's
Weight = 3.5 kg's ( without electrics) 4kg's RTS
#989
and So !....another creative Bro rc Surfer journey begins......this time we are off to OZ !
Two 28" CrackerJack Bro rc Surfer boards being built for separate clients in Down Under OZ !...One Green One Red !
Building boards once all the process development - templates and tooling has been sorted makes it so much easier than the initial process.
Both these clients have been so looking forward to getting their new Bro's wet ! ...so I better get going .........some classic surf in the Bay this
thou - so we will get shaping in the morning .......priorities !........
80kg/sq. Hi- density polyurethane foam cores
#990
Just before Supper - a quick session down at our local famous 'Muizenberg' beach - a mecca for beginner surfers from all around the world ! ......
a touch lumpy - bumpy - windy - even small - YET !....always fun ! .....
http://youtu.be/LOQyylmQWtg
#992
