Question about boat motor+gearbox
Hi, I am new to scale model building.
I've built a 1m scale ship using balsa wood. I will be using one motor with a 50:1 gearbox. It does around 320rpm at 12v and 160rpm at 6v. Would the ship be very slow with this motor and gearbox combination ? I can use 30mm or 40mm propellers.
It will be incredibly slow, deeply frustrating and boring. That kind of RPM is OK for paddlers, but not for props.
A 1M boat with a 40mm prop needs something like a direct drive 545 motor running on 6 volts if it is a displacement model, more volts and a smaller prop if it is going to be a fast boat. A model needs a faster rotating prop than the real thing to give the appropriate looking speed. (multiply RPM by the square root of the scale).
In about 30 years of boating, I've never had a thought about putting numbers on prop RPM, but oddly, matching the motor, hull, prop and power supply has never been a problem. Without knowing what your model is of, and its scale, any reply is pure guesswork, but -
A 1:100 destroyer, real props turning at @300, model props need to turn at least 3000. Small prop, turns fast, long narrow water column,
A 1:100 freighter of the same length might have a prop that turns at @80, model turns at 800. Large prop, moves a lot of water each turn, but not far.
For a boat to move forward by its waterline length in a set length of time, the prop needs to move water equal to the submerged volume of the hull back by the hull length in that time (at least, add a large percentage for slippage). A long way for a fast hull, but not much volume, not as far for the freighter, but a lot more volume to shift.
OK you are not making a speedboat, but I have to assume that you would like to get it back against a light breeze. Most of us do. A light breeze for a full size person is a strong wind for a model.
What is the model of? What is your proposed motor+gearbox?
The model is 1m long and it is made of balsa wood. Would also have a 1.3kg battery on it, plus the motor and some electronics. I think that you are right, a 50:1 gearbox (max 320 RPM) on a 545 motor would be too slow. I am now considering a 545 motor with a 6:1 gearbox, with max. 2660 RPM.
I am more interested in the ship's maneuvers rather than speed, but as you pointed out, it must overcome a light breeze, while I don't want it to be boringly slow. Do you think the 6:1 ratio would be better for this application ?
That is what a model supplier over here recommended for use in a Revell Snowberry a few years ago (although he might have used a 540), so it should be just fine on yours (roughly the same size and weight). I used one on direct drive and about half its rated volts in mine, also a 385 with very similar results. It has always performed well, but having a good controller and remembering that the stick is a linear control that does not need to be flung against its end stops all of the time and not a switch allows very precise control when maneuvering. Remember that a propeller is a part of the transmission system, and acts as a slipping clutch most of the time, compensating for a lot of mismatches further back.
The big trick is to avoid over-thinking yourself into problems that didn't exist before.
