Changing frequency on cheap toy boat
Hi long time member but not a big poster, I have three cheap Ric boats which I bought from Amazon, my grandchildren love them but must be separated when they play as all have the same frequency, help I would at least like to change one of them but unsure where to get the part, not a normal crystal, I have a photo of the remote board.
i would love any help anyone can give.
They are designed as-is. To comply with radio legislation and be as cheap as possible, there are no user changeable parts. To change bands and have it working afterwards needs a well equipped radio workshop.
Generally, they use very non standard signalling protocols, transmit at very low power, and the receivers have very poor selectivity to compensate for the low power. If one gets used anywhere near any hobby grade transmitter which is using any channel in the band, the toys signal will probably be swamped. The transmitters broadcast "somewhere in the band", the receivers pick up everything in that band.
The pale blue thing top right is possibly an aerial filtering coil, the crystal is the item marked XT1 in the low profile can. In this day and age, the crystal is probably not doing any tuning, more likely it is providing the clock for the program that one of the chips is running to do the tuning. A program, once written, is a heck of a lot cheaper to produce in quantity than a physical radio.
No.
Even if the crystal was tied to tuning the radio rather than providing clock pulses for the (assumed) processor in the chip, you would need to do a corresponding change at the other end and who knows just how illegal the newly tuned transmitter would be?. These things were not designed to be modified easily.
