Gas Motor Manual Throttle Possible???? Using motor for unique project.
Hello,
I was wondering if it was possible to convert an RC gas motor to have a manual throttle. I am using the motor to power a surfboard type machine however, all the motors I have seen required several electronic components and a controller to adjust the throttle. I wanted to avoid this and have a throttle by cable input. I'm not sure if this is possible but thought I'd ask some RC pros and enthusiasts about the topic.
Any information is welcome, thanks.
MN
Electronics are used to remotely control the throttle on any engine. In place of the electronics, add a cable from a weed whacker, chain saw, similar yard tool, or a simple piece of string and pull it to rev the engine. Go cart throttles and cables are available at Northern Tool, Harbor Freight and other similar outlets.
