RC Boats General Discussion Discuss general rc boating topics here.
Banzai sports x4 gas motor
Reply
Old 08-06-2018, 12:09 AM
Jester2018
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Banzai sports x4 gas motor
Hi guys hope someone can help my flexishaft keeps coming loose on the banzai motor i checked to see which way the motor turns and it turns anti clockwise but the nut holding the flexi onto the motor is clockwiae so when running it loosens can anyone tell me which way the nut should be in regards to the rotation of the motor.
kindest regards
peter
Jester2018 is offline
Old 08-07-2018, 07:00 PM
Hydro Junkie
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If your engine turns counter-clockwise, you want your collet to tighten clockwise. If it's coming loose, there's something else going on. Have you considered a square drive?
Hydro Junkie is offline
Old 08-08-2018, 07:15 AM
Justaddwata
Justaddwata's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Peter, Welcome to the forum.
If the flex shaft is coming loose I imagine it an issue with how much you are tightening the collet or a problem with the cable itself. Use the correct sized wrenches (not shifting spanners etc) to get a good grip on it. Also be sure the flex is clean and dry where it enters the collet. Where did the cable come from? Realistically I cannot say I have had issue with cables coming loose and I have motors making more power than a Bonzi BX4.
Justaddwata is offline
Old 08-09-2018, 06:59 PM
Ron Olson
Ron Olson's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It sounds like a problem I had. I lost a few new cables with the props at a race. I finally narrowed it down (almost too late) to a bad collet insert. It was just loose enough no matter how much I tightened it with the wrenches it would throw the cables. The collet would grind down the cable just enough to set the cable free under load.
Ron Olson is offline
