Full size boat grease in RC boat
My dad stuffed his new pursuit with Actual, full size boat marine grease. I assume it would be ok, just making sure. Anyone else do this, or is it going to ruin the boat?
If he stuffed the stuffing box, it's probably fine as long as the grease isn't one of the real thick and sticky ones, like a bearing grease. A heavy grease like that will put a heavy load on the drive and COULD actually overload the electronics. I would test it on the bench and see how the boat reacts. If it's showing signs of heavy load, clean out the grease and repack it with something lighter. What I use in on my drive shaft is a water proof lithium based grease.
Very true. And that is the very reason I recommended a bench test. Without knowing what kind of grease was used, I can't(and won't) say the grease is good or bad. I also don't know what kind of boat or, for that matter, what kind of drive shaft was installed in the boat, again making a definitive good or bad impossible
My dad is not as fussy and perfection as I am so he just stuffed it full of marine grease from autozone and called it ok and that it is fine, even though I disagree with it. He also has way too much gap between the dog drive and strut. Again he tells me it will be fine, it gets kind of frustrating on my part. I tell him to store it in the room with the A.C going on hot days, lower humidity, but again, he puts it on the bench in his garage where it is blazing warm in the day and can be like 30 degrees cooler at night. I prefer to keep my models in a good, environment controlled room when not outside being used and he is fine with the model being stored in a 90 plus degree garage in the summer. It drives me nuts, lol He also demands he wants 6s batteries in the pursuit which I believe is set up for 4s. I guess the 120 amp ESC can handle 6s, but not sure about the prop. Well possibly I will just let him do his thing and break the boat, then possibly he will take my suggestions. I just wish he got into RC cars, because boats seem to me, to be a pain, especially these F.E boats. Thanks.
Yup, get the same thing at work all the time. Since I work in commercial aviation, there are written specifications and processes for everything. It drives me crazy when I get told "But we don't do it that way on the floor" or "my lead/coworker/manager says" and they get upset when I ask them if I need to have the FAA audit their shop to verify the work is being done correctly
I wasn't looking at the different types of craft or the ramifications of crashing or storage. I was comparing the attitudes of the people involved and the frustration created when dealing with them. PG was talking about the attitude over storing in a climate controlled area vs in a garage that had temperature swings of 40+ degrees while I was referring to people that think they know all after some rudimentary instruction but no real experience . Both can be frustrating as hell when you try to explain why they are wrong when they won't listen to the voice of reason
