12 cells too much?
NY
12 cells too much?
ok, well today I traveled 100 miles to my "local" hobby shop lol, to get batteries. All they had wer 6 cell packs, I wanted an 8. Anyways heres the setup.
Villain IV hull
single trinity midnight 27 turn stock motor on direct drive
graupner jet drive
tekin marine esc 432M
Question is can the motor handle 12 cells? Previously I've only run as high as 7
I know the esc can handle 14 easily
I really dont want to run only 6 cells, but I cant find specs on these motors, also esc and motor are water-cooled
If its only ify, I've got a spare motor, but I dont really want to blow the boat up.
Villain IV hull
graupner jet drive
NY
RE: 12 cells too much?
thank you so much, I didnt think anyone was gonna reply, ok I'm gonna run 6 for now then, I was gonna splice those packs together tonite, thankyou for saving me a lot of money to say the least.......There are motors that can handle that though right? Any suggestions on a fairly inexpensive motor meant for high voltage?
OK
quicksiler,
Take a look here;
http://www.mabuchi-motor.co.jp/en_US/technic/index.html
It will tell you a lot about motors. (I'm sure there are other simular sites, I'm just not aware of them.) In a very general way all of that manufacturor specific information does carry over for other manufacturors motors. There are exceptions too, as in motors that are not exactly built in a 'standard' manner. Descriptive words like 'Turbo', 'Super', etc, etc, are sales department specs, not 'real world' stuff, have very little to do with actual performance (except for sales!!). There are 'higher performance' motors available but none of them are really associoated with 'cheap' in any way - lol. There's nothing really wrong with 'pushing' a motor unless you push it too far. Over-volting a motor is certainly possible. Going too far without adequate cooling is also possible, 'probable' is more like it though. And it's a fact that a motor can be pushed far enough that running Niagra Falls past it just isn't gonna cool it enough to keep the conductors from melting. It's sort of a 'viscious circle' thingy, everything affects everything else and the 'trick' is knowing when to quit (always quit before you think you have to).
Having said more than I intended, and more than you ever wanted to hear, I'll do that 'trick' thingy and quit.
- 'Doc
Take a look here;
- 'Doc
My Feedback: (24)
quicksiler: Here is what I would do. Since you want to run 12 cells, get an E-Maxx motor, or a Villain EX motor. They bolt into the same place as a 540 motor (like your Trinity) and they thrive on 12 cells! They are also fan cooled so that helps with the heat department but you can always add a water cooling coil if you don't have one in your boat already.
Try it out and run only one minute then bring it back in and check the heat of the motor, the esc, and the batteries. If they are overheated, stop running. Get a smaller diameter/pitch prop, and try again for one minute. If you have no overheat in one minute, then try two, then three, etc. This will help you find the right combo of prop for your motor and voltage and you won't fry things in the process.
NY
ok that sounds like a solution, one tricky thing is I'm running a graupner jet-drive in the Villain, so I cant really mess with the prop(impeller), but I suppose I could still mess with the voltage once I get one of the above motors. I'm hopefully gonna do a test run tommorow, if I can get my steering servo mounted. I guess Ill go from there,
thank you both for your excellent advice
i run a trinity 19th chameleon pro 2 and i run it one 12 cells and i am stil on my first set of brushes all i have to do every couple runs is sand down the comm tog et off the build up otherwise it revs like crazy
