RC Boats General Discussion Discuss general rc boating topics here.
RC Surfer
Reply
Old 05-09-2011, 12:53 PM
  #2576
edfjetliner
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: RC Surfer
Yeah I will run it I just wish Iknew what the specs where so I dont fry anything up Im not even sure if I can run a lipo with the ESC? Thanks for your reply
edfjetliner is offline
Old 05-09-2011, 01:16 PM
  #2577
Hans N
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
But Ed,
get rid of the Tamiya plug on your ESC. That is not suited for higher Amps. Replace them by 4mm gold-plugs (at least that is what I use).
Hans N is offline
Old 05-09-2011, 02:10 PM
  #2578
bingo22
My Feedback: (16)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
edfjetliner
The esc looks like a Aqua Craft 45 amp for NiCad and most likely is with the Tamiya Plug, and the motor also looks like a Aqua Craft about 1750 KV they have a 5mm shaft and 36mm Diameter
bingo22 is offline
Old 05-09-2011, 02:40 PM
  #2579
itsfishi
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
dan im with canazi dont think its your motor, its weird. maybe you could email steve at offshore and see what he thinks or post in the fast electric forum those guys will know something for sure. for some reason and i dont really think there is one i keep thinking maybe esc. maybe a dumb question but is your batt getting a full charge? good luck with it 00 these things can be ultra frustrating.
no surfing this morning found cracks in lisa around top of her legs from her butt to her #@$%. too many times over the falls/closeout barrelled and just plain hammered i reckon, maybe get her sorted for the arvo.
edf why dont you try ed himself at rcsurfrider. to try it out start out with small prop give it a short run and check if its getting hot or not then work up. dont see why you couldnt use lipo its just a battery. if you ran 7.2 nimh then 7.4 lipo should be sweet.
later
itsfishi is offline
Old 05-09-2011, 04:42 PM
  #2580
edfjetliner
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Bingo Ithink you got it they very well may be aquacraft
Old 05-09-2011, 04:52 PM
  #2581
edfjetliner
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
So if my ESC is an Aquacraft 45 amp which it very much resembles with tamiya plugs can I only use Nicads? or should i solder
on some deans and try to run a lipo, I cannot get a hold of Aquacraft to find info on this ESC thanks.
Old 05-10-2011, 12:23 AM
  #2582
Hans N
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ed, it is wise to only use NiCd or Nimh with your setup.
If you were to run lipo with that ESC, you would probably drain the lipo too much before you would notice that the lipo is getting empty.
By then it is too late and you have damaged your lipo.
You can charge it again, but it will not hold as much mAh as before. And probablyt hte pack wil start to swell (sign of mis-used lipo).
To be safe just Nicd or Nimh.
But then the next question comes: how old are the NiCd packs you want to use?
And how long has it been since they have been used?
If the packs hve been retired for a couple of years, I am afraid they will not work so good anymore.
You could try to cycle them several times (charge - discharge).
But even then it will remain doubtfull if they can deliver the Amps wanted in full action.
Before we go any further please share with the details of your Nicd pack(s).
- number of cells
- mAh
- age / last time used
Then we can give you proper and direct advise.
Hans N is offline
Old 05-10-2011, 12:30 AM
  #2583
itsfishi
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
good point hans i forgot about cutoff for lipo
itsfishi is offline
Old 05-10-2011, 12:35 AM
  #2584
R a i n e r
R a i n e r's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Ed,
a good, affordable and proven-in-use starter set is:
LiPo (2 cells, 5000mAh):
http://www.hobbyking.com/hobbyking/s...dProduct=14320
http://www.hobbyking.com/hobbyking/s...dProduct=14377
ESC (Seaking or Turnigy, 60A)
http://cgi.ebay.de/Seaking-60A-Brush...item1c16fd8f50
Watercooled brushless motor:
http://cgi.ebay.de/Brushlessmotoren-...97528234284222
You will sure find these products at Ebay-USA and HobbyKing-USA, too.
Take care!
Rainer
R a i n e r is offline
Old 05-10-2011, 12:50 AM
  #2585
itsfishi
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
imo get a 36 size motor
itsfishi is offline
Old 05-10-2011, 12:53 AM
  #2586
R a i n e r
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
My 28ers work fine in both of my surfers - power enough - by far ;-)
However, you need a new motor mounting angle for 28-motors.
What is the advantage of 36-motors?
Old 05-10-2011, 07:45 AM
  #2587
edfjetliner
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for the info everyone getting closer to starting work. Yes you are right, Iknow lipo's pretty well and I will probably just run a nicad for now, intill I can find out more info on the esc thanks.
right now no Nicads only around 20 lipos, that is all that Iuse in my planes at the moment, but for boats can you get longer run times with Nicad or Nimh? my next set up I purchase for lisa will be from
hobbyking full brushless, lipos, 2.4ghz
Old 05-10-2011, 03:17 PM
  #2588
itsfishi
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
rainer not saying a 28 motor wont do the job they can but in my experience it got really hot and was overworked a 36 motor can handle more amps bigger props etc without prob. gives more options and more power which i really like. i think you will find most modded brushless boards are using 36 motor.
i started with 28 then went to 36 so i recomend start with 36. saves $ down the line, wont want to go bigger than 36 but good chance wanting to upgrade to 36 leaving obsolete water jacket motor mount motor etc.
itsfishi is offline
Old 05-10-2011, 04:25 PM
  #2589
Justin-san
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Jetliner,
I would get the Turnigy Marine 60A Brushless Boat ESC and 3660SL 3060kv Brushless Inrunner (WaterCooled) and 2 or 3 Turnigy 4000mAh 2S 40C Lipo Pack (USA Warehouse).
I have this set up and it works fantastic.
I work in Torrance CA and can show you the set up if you want.
Justin
Justin-san is offline
Old 05-10-2011, 07:28 PM
  #2590
itsfishi
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
rainer maybe this 28 size would be interesting.
http://www.hobbyking.com/hobbyking/s...dProduct=17152
itsfishi is offline
Old 05-10-2011, 09:37 PM
  #2591
edfjetliner
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Justin sounds real good and USAwharehouse even better, that would be great if I could see that set up I am usually driving around Torrance atleast once a day.
how much run time are you seeing with that set up?
Old 05-10-2011, 11:37 PM
  #2592
Cananzi
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
guys
i recieved my 4s 5000mah 25c lipos yesterday....i havent got my motors i ordered yet so i thought i would give the leopard 3180kv a shot on the 4s board i have just done.
all i can say is ..........................Lmfao
it is ridiculous!!! I lined it up at a wave face and hit it head on it aired so dam high couldnt believe it houston we have lift off!!. lucky i ordered a few slower motors. i ordered 1500kv ,1800kv , 2300kv so i can have a good play around.
I think 1500kv will be spot on cant wait
sold the 3s board today..was sad to see it go specially cauz i finally had it running and surfing good but i have got another surfer coming (venom) that i won for $10.50 off ebay hahah score!!
Cananzi is offline
Old 05-11-2011, 07:11 AM
  #2593
Justin-san
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Jet the batts are from the USA wharehouse but the moter and ESC are from China. I took it out the other day to run the new batts but Lisa's foot came apart and I had to end the session short so I dont have a run time on the batts yet maybe this weekend. I could bring it into work tomorrow Thursday and/or Friday and meet you some where. If you look back at the posts you can see my set up, pages 98, 99, 101.
Old 05-11-2011, 08:31 AM
  #2594
edfjetliner
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Looks good the pics will work. Also have you found anybody to take pics for you yet? let me know. Cannon 40d, but if you shoot for a living then Im sure your geared up.
Old 05-11-2011, 09:20 AM
  #2595
Justin-san
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sounds good Jet. One thing I live in South OC and usually go out at Doheny or San Onofre.
Old 05-11-2011, 04:34 PM
  #2596
Jimi Findrix
Jimi Findrix's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey Crew,
How 'bout posting a few more RC Surfpics and vids.
Would be a lot more inspiring seeing some of your latest gear in action.
JIMI
(Geraldton - W.A.)
Jimi Findrix is offline
Old 05-11-2011, 05:59 PM
  #2597
RC HAWAIIAN STYLE
RC HAWAIIAN STYLE's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
jimi
unreal flip, the waves are crapy on maui , but i have beenworking on a new board a winger swallow tail its 32 in. long and 12 in. wide ,, i put a lisa next to it so you can see the size differice .
fish i was thiking for a motor set up 4 cell 5000 MAH lipo/ 1900 Kv large motor/ ESC 150 AMPetti , my question is what would be my RPM's and how do you come up with the anwser. thank you
john maui
ID:	1607293   Click image for larger version
ID:	1607294   Click image for larger version
RC HAWAIIAN STYLE is offline
Old 05-11-2011, 07:42 PM
  #2598
itsfishi
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
john rpm is worked out by multiplying the kv of the motor by the voltage of your battery so for your setup
1900kv x 14.8v =28120rpm
remember also on a full charge 4s you will be starting with 16.8v (31920rpm)then going down to whatever your cutoff is say 3.4v/cell is 13.6v (25840rpm)
thats a difference 6080rpm over your run which is quite noticable compared to rpm drop on 2s setup.
imho that sort of rpm is perfect, of course ive only ever had a nqd and maybe your boards would handle more.
also i would cram the biggest batt that would fit or even better 2 smaller ones in parrallel to make one bigger batt
if i got any of this stuff wrong please someone correct me
good luck with the board john it looks awesome
later
itsfishi is offline
Old 05-12-2011, 02:44 AM
  #2599
Jimi Findrix
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
John Maui,
That new board looks so sick.
I love it.
You sure are keeping busy with the shaping.
Hope it surfs really well.
JIMI
Old 05-12-2011, 08:04 PM
  #2600
Cananzi
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
hey fellas
couple of pics from today. conditions weren't even worth going out but still went out for 2 packs.
ID:	1607833   Click image for larger version
Cananzi is offline
Contact Us Archive Advertising Cookie Policy
