RC Boats General Discussion Discuss general rc boating topics here.
RC Surfer
Reply
Old 12-17-2010, 10:03 PM
  #1401
Jimi Findrix
Jimi Findrix's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: RC Surfer
Seb,
I have been thinkin' 'bout your 4mm rudder shaft / tube set up for your homestyle fins.
Your idea of use cut down propshaft and tube is very good and you said fhey fit well so I am ivery nterested in this.
What are you using for a tiller arm and how are you attaching it?
Are you using the stock one somehow?
I did find these on line and although they are obviously a bit long I guess they could be cut down to size and might work well.
http://cgi.ebay.com.au/RUDDER-ARM-4m...item1c17f2d451
Let me know what you are using and if you think these could work out.
Sea ya.
JIMI
Jimi Findrix is offline
Old 12-17-2010, 10:55 PM
  #1402
skowowski
skowowski's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Guys,
Put this mornings footage on YouTube, Check it out here:
http://www.youtube.com/watch?v=Djt062gaImc
The surf was less than a foot, but I still manage to rip it up.
Enjoy, Seb.
[youtube]http://www.youtube.com/watch?v=Djt062gaImc[/youtube]
skowowski is offline
Old 12-17-2010, 11:18 PM
  #1403
skowowski
skowowski's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Jimi,
The rudder steering arm I am using is off an old airplane steering arm. The one you are looking at on eBay should be fine. Just remove the grub and file down a 3mm screw and that way you can use a pair of pliers to tighten it up.
Remember to file the side of the rudder strut so the screw sits against a flat area on the rudder strut, see pic.
I used a 4mm tube and pushed it in the rudder slot and marked where I needed to cut it. Now you will need to find a bullet plug and cut the end of it off and slide it on the rudder strut so it fills the end of the propshaft tube that is cut. Once you cut it, you will see that the uncut end is 4mm and the cut end is 5mm, the little ring of brass from the bullet plug seems to fit perfectly over the rudder strut and nicely into the propshaft tube. This will give it a good seal and you can fill the tube with grease.
To make the fit, get the 4mm propshaft and file down 2 sides of the threaded end, cut a fin out of plastic (I bought a plasters tool to smoothen out plaster, 2 bucks from bunnings) and cut the slot for the rudder strut to go into and used super strength shelleys epoxy to set it in place. Make sure the rudder strut is set further to the front of the rudder than the centre or it will have to much force on it to push the rudder back to center after a turn.
Then fiberglassed it in with laminating resin and cloth then painted then filler coated it. It is the same as the fin for my larger home-made surfer and is just as strong, just a little smaller.
Once the tube is in place (a little superglue will keep it firmly in place and side in the rudder and into the steering arm and mark where to cut it. Once you are happy with the rudder and tube, file down the rudder strut where the screw will tighten against the rudder strut. MAKE SURE YOU HAVE THE SERVO CENTERED AND GET AN EVEN LEFT AND RIGHT TURN BEFORE YOU MARK WHERE TO FILE DOWN A SPOT ON THE RUDDER STRUT.
Try it out with out a horizontal wing inserted, it might be perfect for you. If you do want to fit in wings, just get a hacksaw blade, snap a 2-3cm piece, heat it up and push it through the rudder. Make sure it is at a slight downwards angle.
Hope this has been helpful.
I wish you had a helmet cam, between you, John in Maui and I, we would be able to put up 15 minutes of footage to watch each week!
Seb
ID:	1535523   Click image for larger version
ID:	1535524   Click image for larger version
ID:	1535525   Click image for larger version
Old 12-17-2010, 11:59 PM
  #1404
Jimi Findrix
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Seb,
Well done mate.
I do have a Gathcam.
Just have not been using it.
Have not even been gettin' any waves lately.
We had a look this morning and there were waves but it was too windy to bother.
"Point Moore" is the most westerly part of the town and the wave is on the northern side so offshore there is SE.
It is very exposed and the wind comes across the bay on the southside and hit the waves as they wrap around the shallow sandbank.
The beach is flat for about 50m out and so there are no dunes or anything behind you as you face the wave, just ocean (behind you).
It is a fickle set up.
 Not enough swell for some of the sheltered reefs on the north side that I was hittin' in winter and the beachies on the south side are straight and rediculously boring at the moment.
So I have just been working on the boards trying out a few more ideas attempting  to keep out water.
Sea ya
JIMI
Old 12-18-2010, 12:05 AM
  #1405
goggz
goggz's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
that'l teach me for teaseing the dog....
ID:	1535533   Click image for larger version
ID:	1535534   Click image for larger version
goggz is offline
Old 12-18-2010, 12:14 AM
  #1406
Cananzi
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ahahh Goggz!!! did it live on???
beautifuldog too mate what is he/she? looks a bit like a bull terrier??
Cananzi is offline
Old 12-18-2010, 12:26 AM
  #1407
goggz
goggz's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
he got it good riddled the board with holes.. killed the receiver... i thought these things were unsinkable!!...... my lovely hound is part english bull terrier / boxer... he's about 5yrs old [:-]
goggz is offline
Old 12-18-2010, 12:54 AM
  #1408
goggz
goggz's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The board has had a hard life.... good n the bad.... wasnt worth the hassels trying to fix a leaky turd... Ended up taking the running gear out of Surf curls munched xt.... i will be sticking it all into the board im shaping here...
ID:	1535544   Click image for larger version
goggz is offline
Old 12-18-2010, 01:11 AM
  #1409
Cananzi
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
speaking of bad times and good.well it was bad times for me this arvo. the engine mount snapped clean whilst on my first pack!! the leapard motor is a bit of a beast lol. was getting huge airs with it but i think its too much power .
Seb
I went to get some more surfers from that joint................all gone!!! bummer!!
Cananzi is offline
  #1410
TFLHOBBY-Candy
TFLHOBBY-Candy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Wow ,It is with a large wave .a strong Dog ! a  swimming dog!
TFLHOBBY-Candy is offline
Old 12-18-2010, 01:19 AM
  #1411
skowowski
skowowski's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Cananzi,
I know, the lady called me when they had one left (yellow board so I said thanks but no thanks) They sold out quickly!!
Is there any vibration in your motor? I use 3000-3800kv motors and have never busted up a mount since being on the flexishaft. Solid couplers killed a few! They are easy enough to make, just a hassle to have to repair something. You are using the flexishafts right?
I was down Burleigh today, waves were small but still managed to rip it up. Where do you usually RC Surf? I will be down Dbah tomorrow morning early fighting for a wave with 500 other desperadoes.
Seb
Old 12-18-2010, 05:05 PM
  #1412
Jimi Findrix
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Goggz,
At least it was your dog, adds a whole new meaning to JAWS.
I hate it when other people let their dogs run around crazy on the beach, then they just sit there laughing while the dog tries to eat your model surfer.
Cananzi,
Get one of those new boards you saw on ebay and put your gear into that.
Just jokin'.
Bummer the mount broke bro.
Good luck finding a cheap NQD board.
Well light winds were predicted for the mornings over the weekend, but it is screamin' 50km/h to 75km/h gusts offshore again???
Don't think I will be going surfing today!
JIMI
Old 12-18-2010, 05:38 PM
  #1413
skowowski
skowowski's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Guys,
Goggz, I'm still blown away you let your dog rip your surfer up. I'd tackle the mutt before it got it, and if it did, i'd then go medievil on the owner.
Surf off Miami (Gold Coast) was perfect for RC Surfing this morning, 1ft with 20-30 meter rides left and rights. However, after one battery the rain kicked in for the day. Managed to get almost 3 minutes of good footage from one battery session, will post on YouTube when it has uploaded. I am so used to posting vids with 3 second rides ending with an air, nice to finally get some face riding time.
Each video I upload is about 500mb and takes about 6 hours to upload. If I upload a 100mb file, the quality is bad, so if you upload a video to YouTube, upload the highest quality file you possibly can so it will be the best possible quality.
At least I got a few waves today : )
Seb.
Old 12-18-2010, 07:24 PM
  #1414
surfcurls
Banned
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Cananzi, Email me at surfcurls@aol.com
I got your ebay message ...
surfcurls is offline
Old 12-18-2010, 10:15 PM
  #1415
Cananzi
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Seb
yeah on the flexi shaft. I put another mount and motor in and made sure the motor was in line even tho its a flexi .haven'thad a problem weird. it is 1700watt motor so maybe ittorquesnapped the mount??dunno
I dont go to any particular spotbecausei just throw it in the car and have a go after i go for a wave. Went to fingal this morning (dreamtime beach) it was so glassy and perfect bout 1.5ft it was the first time i really got to have a good go on some decent waves with the rc.
Jimi
the people that make thos new surfers should donate a few to groggz dog to chew on cauz thats all they look good for lol ;-)
Cananzi is offline
Old 12-19-2010, 02:27 PM
  #1416
goggz
goggz's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
skull cheak'n out his new stick... hounds waiting for the NQD lunch menu [:-]
ID:	1536152   Click image for larger version
goggz is offline
Old 12-19-2010, 11:05 PM
  #1417
Jimi Findrix
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Goggz,
Looks like Skullman is pretty stoked with how his new shooter is coming along.
Goin' for a quad eh?
Did Skull get any damage from JAWS or just the old board?
He looks ok in the pic.
Have you done anything to strengthen the Skulldude or is he standard.
I have 4 old Dudes with fixed ankles / legs / arms / heads and I have sanded the repairs ready for CF job.
I have been putting it off for ages because it is such a fiddly messy job to do.
But now I have been getting a few other hulls ready to go I have to do the Dudes too.
Wind was howlin' again this mornin' so I did not bother lookin'.
Did get an email from Bob, he reckons there were some good 1' to 2' rights where he lives @ "Mahomets".
Mightget a run at dawn tomorrow if the wind mellows out a bit.
Sea ya.
JIMI
(The Land of Oz)
Old 12-20-2010, 12:28 AM
  #1418
skowowski
skowowski's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey Guys,
Some more footage!
Some super fun long left and rights, best it has been in while. Today was offshore for this first time in months, should have some sick footage, will post tomorrow. Got one sick barrel and came out, but realized I forgot to turn the cam back on after changing batteries.... very pissed indeed!
[youtube]http://www.youtube.com/watch?v=cWNUwzGZzfo[/youtube]
Enjoy!
Seb
Old 12-20-2010, 08:03 AM
  #1419
goggz
goggz's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Jimi skull got two k9 tattoo's.... he is surf harderd..no standard skull... ive modded him to handle the bigger surf with fibre glass rovings... Dremeled deep channels following the mold seams on his body and filled with mixture of tuffness its like giving him double bones.. plus he's got a covering of resin to save the wetsuit paint job he's got to be tuff to surf with the locals here ...ive been thinking of covering him with fibregass cloth once the stick is complete tho there isnt really the need to as he's doing fine.. so far
pic's of the proto type board... Bad Omen, ive started to install the hardware ie. motor, servo and linkage
ID:	1536335   Click image for larger version
goggz is offline
Old 12-20-2010, 11:09 AM
  #1420
jocktime
jocktime's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Nice video Seb.
Your board turns like a dream....
It's always great to see what others are doing.
As you know, we love videos. Great job.
Johns in California doing some surfing and filming.
We hope to do a co-production video with Pure Digital Maui
when they get back from filming the Triple Crown.
Time and waves permitting. jock
jocktime is offline
Old 12-20-2010, 12:58 PM
  #1421
skowowski
skowowski's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Jock,
Thanks for the compliment. Since I put in the wing rudder, my board is holding solid on all waves.
This footage is from yesterday, the conditions were perfect!! Best waves I've surfed is months!
[youtube]http://www.youtube.com/watch?v=PG0ftMvpwNQ[/youtube]
If you guys ever want to use some of my footage in your movie let me know and I'll send you some raw footage.
Seb.
Old 12-21-2010, 05:02 AM
  #1422
Jimi Findrix
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Nice airs Sebski!!!
Old 12-21-2010, 08:35 PM
  #1423
jocktime
jocktime's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Seb,
What format are you using with your
downloads to YouTube............jock
jocktime is offline
Old 12-21-2010, 09:14 PM
  #1424
skowowski
skowowski's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Jock,
I upload my videos as AVI files so when YouTube converts and compresses them, they will be of the best possible quality.
My last video (which I honestly think is some of the best RC Surfing footage on YouTube since "radiowaves", home-made surfers excluded of course!) was 780mb. As I film with a camera strapped to my head, I shoot with the zoom a fair way out and have to digitally zoom in to capture, so quality is reduced, so uploading AVI quality is my only option.
You can convert it to an MP4 file (which YouTube will do anyway) and the file will be smaller but the quality will be about 75% of what it will be compared to the same file uploaded as an AVI.
Hope that is helpful.
Seb
Old 12-22-2010, 04:37 AM
  #1425
Cananzi
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
guys
does anyone know where i can buy engine mounts?
Cananzi is offline
Contact Us Archive Advertising Cookie Policy
