RC Boats General Discussion Discuss general rc boating topics here.
RC Surfer
Reply
Old 02-22-2008, 07:16 PM
  #151
adrian dixon
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: RC Surfer
Well i havent run it with the drill motor yet but it is fairly torquey. i will let you know how it goes.
adrian dixon is offline
Old 02-23-2008, 04:29 AM
  #152
Paolo.75
Paolo.75's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
UMM...too much weight near the tail with the 4AA batteries...better choiche is put a ESC instead the stock servo-microswitch off-full throttle, then move the receiver battery pack in the front.
Paolo.75 is offline
Old 02-24-2008, 12:55 AM
  #153
adrian dixon
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yeh i am going to buy a new esc soon this is just a temporary thing so i can still run it
Old 02-28-2008, 09:02 PM
  #154
surfcurls
Banned
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
How do I find that brass fitting that is on your motor shaft, so I can use the stock prop shaft on my NQD ?
surfcurls is offline
Old 03-09-2008, 03:53 AM
  #155
BigWaveMax
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Put an emty small plastic water bottle between his legs and duct tape it. That will make him upright himself
BigWaveMax is offline
Old 03-10-2008, 08:35 PM
  #156
waverat
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
it's good to see this surfer hasn't disappeared! I've only just got mine and found www.********.com to be a bit old, so I searched the 'net for here. Some good feedback and mods here!
waverat is offline
Old 03-12-2008, 04:18 PM
  #157
alloutcustom
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
does walmart still have these? Where can i get them cheap?
alloutcustom is offline
Old 03-13-2008, 01:46 AM
  #158
surfcurls
Banned
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I Have New NQD Surfers ready to go , they are the Most Similar to the Kyosho Lisa.
See My Web Site www.surfcurls.com
[8D]
Old 03-16-2008, 03:12 PM
  #159
jpaw
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You seem knowledgable about these rc surfers. Can you tell me out of the 3 I find online, which is the best 'stock' one to go for? The NDQ Lisa, the Kyosho or the Shark Board? Considering ease of upgrades and overall construction. Thanks
jpaw is offline
Old 03-26-2008, 09:24 PM
  #160
nathan77
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi
Purchased the surfshark surfer 4 months ago and have been very unhappy. I am on my third one now and seem to have problems again. The body gets stuck on th turn position and it will not return. Let me tell you thet when it is turned over this is a pain in the but and it will not self right. Has anyone else had these same problem. Can the part that makes it turn be replaced with a better quality. I am not sure that it is worth stuffung around with this model anymore or to try to purchase a lisa or kyosho.
If i was to buy a copy lisa and gut it with new parts would it be better or are the originals a better hull designs.
I have just entered the craze and am hooked
I don't want to spend money on something that will not be good in the end.
any help would be great
nathan77 is offline
Old 03-29-2008, 09:42 PM
  #161
munro1656
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I've been serching around to buy a kyosho surfer in australia and not much luck anyone got any links for one. these things look like fun, from what i read the chinese version is not so good
munro1656 is offline
Old 04-01-2008, 10:24 PM
  #162
toyguy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have the original Kyosho Surfer Lisa. I put in a 19 turn spec motor with a good forward only (novak cyclone) speed controler and run a 7 cell batery pack and stock prop. I want more performane-any ideas on a diferent prop or a brushless setup. I've been considering a supervee motor and speed control but maybe it's to much power and I'm not sure how it would perform on a 7 cell pack-I don't think there is enough room for more cells.
toyguy is offline
Old 04-02-2008, 02:36 PM
  #163
alloutcustom
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I would recomend a outrunner for you guys. With high KV. Only because you would get long runtimes. I foyu are looking for speed though, then i would recommend a feigao C class inrunner. You will need a 100A esc and a smaller prop to start of with(to be safe)
Old 04-07-2008, 05:04 AM
  #164
nathan77
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You seem to know about these surfer's. what do you think of the cheap lisa's from china can they be trickedup or are they just a waist of time. On my third boardshark and they are not any good. W ant to trick up something for speed and something with a speed control on it that will surf properly. Any ideas would be great
nathan77 is offline
Old 04-15-2008, 02:14 PM
  #165
SURFMIKE4
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
hey all just back to the cold califronia it to for me to surf here so iam play with my boardshark but as we all know they ar junk , they have the self righting thing that it will not do, but i think i found the out how to make them work , i was tapeing lead to the bottom of the board an put it in the pool an then tiping with the surfer in the center an after add lead it start comming back up by itself , an i just finsinh cut a hole under the motor an add the weigth into the board
an glue it in now just waiting for it all to dry for the surf test will let you know what up .. has any one already done this
for i do not have a scale so ido not know how much lead i added two small about the size of 3/4 long 1/2 wide
maybe this is the away to go with these boardshark junk
SURFMIKE4 is offline
Old 04-16-2008, 11:10 AM
  #166
gnarbrah
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I''ve done some mods on my boardshark (look back a few pages) and I haven''t messed with it since. Kind of stuck and miffed about the non self righting thing. Max told me to a water bottle between his legs and although it won''t look the coolest it might work so I''ll probably give it a shot.
Mike - let me know how the whole lead in the bilge works out. I like that idea. Ever since I put the new motor and electronics in him he runs great I just need him to pop up when he gets slammed!
gnarbrah is offline
Old 04-16-2008, 04:45 PM
  #167
biglenn
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi all. I recently got myself a NQD Surfer off the internet for 25 pounds (im in the UK) which i thought was a steel. i took it out for the first time and was a little dissapointed as it would not self right itself 90% of the time and one of the surfers feet actually came off the board. Although a lttle slow it was good fun in the small surf and its great as i live on the coast.
I have since re-attached the surfer so that he is fixed firmly to the board and had to add a few splats of silicon to stop some water getting in. Have taken it out 3 times this week and its awesome - the surf has been perfect! I got a 3700mAh batt due in the post so hoping run time will increase. I did manage to break a blade off the prop but it even came with a spare one!
I used to race radio controlled cars along time ago and my RC knowledge is a little rusty! i still have a few motors and bits that may come in usefull - gonna go and have a rummage.
Great website - stoked i found this forum!
biglenn is offline
Old 04-26-2008, 11:17 PM
  #168
dacaur
dacaur's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
My local Toys R US just had a clearance sale on the boardsharks surfer, I bought 2 of them for $15 each.... I figured an 8.4 volt battery pack is almost that much so even if the surfer is junk, I'm still good One works great, but the other will not turn with the lid on... the rudder will turn a little with the lid off but not very far, but doesn't turn at all with the lid on, the turn motor just runs and runs.... I haven't read the whole thread yet, but has anyone else encountered this?
dacaur is offline
Old 05-02-2008, 10:30 PM
  #169
jocktime
jocktime's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey Morty,
Could you show me some pic's of
the RC Surfer you built? Also, some info
on the Mods you used. Here is a few
pic's of my Lisa mod.
Thanks, Jocktime
ID:	941792   Click image for larger version
jocktime is offline
Old 05-04-2008, 04:41 AM
  #170
biglenn
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ok, i managed to pick up a Chameleon2 motor for next to nothing and was wondering what mods i need to do to get it running in my NQD surfer? Its pretty standard at the moment and i am stuck at the first hurdle! Doh
biglenn is offline
Old 05-04-2008, 06:51 PM
  #171
jocktime
jocktime's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hello,
For my Lisa I use the Airtronics MX-A radio, 102Z Servo
and receiver that came with it. Viper RV MAX
waterproof ESC, Method R 19x2 motor, 6 cell 4600mah battery,
with extra amount of lead in builge to help
with righting. For a non brushless it runs well.
Jocktime
jocktime is offline
Old 05-05-2008, 01:07 AM
  #172
toyguy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Do you use the stock plastic kyosho prop?
toyguy is offline
Old 05-05-2008, 01:12 AM
  #173
jocktime
jocktime's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Stock prop for now, thinking of
changing shaft and prop to
stainless for rust problems...........
jocktime is offline
Old 05-05-2008, 07:06 AM
  #174
MiFi
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi jocktime...could you please take a picture of your self-righting construction???i have to build something like that too and maybe your construction would help me.
thx micha
MiFi is offline
Old 05-05-2008, 01:06 PM
  #175
biglenn
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
my prop, shaft and connection to the motor is all standard. What is it i need to get the new motor in? Not sure i can get the connecting nut off the old motor?
Can i get a motor coupler from a model shop and remove the plastic standard one?
biglenn is offline
Reply
Display Modes
