RC Surfer
#2401
RE: RC Surfer
well i must have done something right. both packages i been waiting on to finish board have arrived today. public holiday tomorrow and the next 6 days off work. gonna be building like a mad man.
happy easter
happy easter
#2402
RE: RC Surfer
Well I just gave my new battery packs a run and I was quite impressed with their peformance. My new packs are 2s, 20-30c discharge 5000mah, and noticed no real drop in power when compared to my 2s 30-40c 4000mah. I had a run time of about 18 minutes flat stick.
Bad news is I jammed up another flexi shaft. Im guessing I might have damaged the shaft when taking it in and out when regreasing it, but im still scratching my head as this is the 4th one ive managed to jam up so far [&:]
#2404
RE: RC Surfer
salty
when you solder the hole up, block the other end and blow really hard down the shaft to see if the hole is soldered properly,if air escapes its not soldered properly.hope that doesnt sound to suss lmao
and just regrease after each session and you shouldnt have a problem im still on my origanal shafts except the first one i had.
good luck mate
good luck mate
#2405
RE: RC Surfer
Yeah you might be onto it Cananzi... Last one I just wrapped some tape around it, and thought that should keep the grease in, but obviously not. The shaft got so hot that the tape melted off and all the grease must of escaped then jammed up. Cant believe how fast it happens though.
#2406
RE: RC Surfer
salty
seb uses these shafts also and from memory he tryed all sorts of stuff to cover the hole but the only thing that works is solder. Once you solder the hole air tight they are flawless.
if your not to keen on soldering take the shafts to a hobby shop they will probly solder them for you but they are really easy to do.
#2407
HI
RE: RC Surfer
mr fish
this is john from maui and yesterday my seacut o i mean sea king fried .,up in smoke .. mr fish you had a good spot to get them cheap . thanks for the help john
#2408
RE: RC Surfer
no worries john glad i could help.
got all stuff to finish board yesterday,stayed up till 4am working on it. then back at it at 8.30am today. nearly got it all in and finished. just doing some testing.
testing the motor and new flex i noticed that the stuffing tube is getting realt hot ,like too hot to touch if i kept on the throttle, does anyone know if this is norma? l im worried its gonna melt right out the bottom of the board. it is 4s 2300kv so realy high rpm, maybe its just that.
just put the watt meter on it on the bench no load obviously. 16.77volts 12.2amps 201.5watts
ill chuck a prop on and try and get a reading in the bath soon.
have a good one guys ill hopefully get a vid later today or tomorrow
#2409
RE: RC Surfer
john was it that you wanted to know where to get esc, if so its hobbyking.com you are probably after the 120amp which is $50 the 60amp comes up as $57 but if you just stay on the page a while the supposed one time offer comes up at $40(it always comes up). somehow i dont think you will have use of 60 amp though lol.
tested out the new setup today
1st test in bath with watt meter 16volts 50.5amp 803watts did not hit full throttle as water was flying
next i went down to the flat water spot and yeah it goes hard. half throttle is like flat out on the old setup.
went full throttle from half throttle and it just flipped.
basically its too powerful. will have too get lower kv motor as i thought.
had a few leaks so not much of a test but will sort that out tonight and get back into it tomorrow and into the surf.
flex seems to be holding up great but really only was running for about 6-8 minutes.
cant wait to get this thing in the surf
trying to get vid uploaded but having probs
cheers
cheers
#2412
RE: RC Surfer
Hey guys.
Went surfing on Wednesday after work. The tide was low, and my board hit some submerged rocks. I didn't know they were there !!. I had no steering, so I watched my board get further and further away . When it looked like it was pointed towards shore, I would hit the throttle, but that was useless.
Eventually it got so far away that the reciever was out of range. I'm using a spektrum AR6110e reciever. Apparently, this is made for park flyers, and does not have a great range. Yup, I agree ! I could see the board way in the distance scooting all over the place eraticlly, heading out to sea. Crap. I also was using a new lipo, so I knew it would be drained to far ( esc still set for NiMhs ). $70 battery. Double Crap.
Eventually it started drifting east and towards shore ( jagged rocks, actually ) I thought about just leaving it and hoping that some one would find it and return it, because I have my phone number in side it.
I walked back to the car and put my radio and bag of batteries in the trunk, but decided to go back and have a look. I went to the top of the cliff and it took 15 min to spot it. Wow ! it was a long way out, and just visible, but slowy moving east. The waves looked like they were coming in, so I thought I had a chance. After a while it floated near enough to the shore, that I thought I might be able to snag it with my " Ron Popeill Pocket Fisherman " I just had a weight with no hook on the line. I must have tried 100 times to snag it. No luck .The board was now on it's side with lisa face down in the water. It looked like it was still heading in so I waited.
I was able to finally grab it near the shore where, luckily , the rocks were low. I was soaked and my hands hurt from fallin on the sharp , slippery rocks twice. From the time I lost control to the time I grabed my board was just over 2 hours. Not fun.
Turns out my servo arm had split , causing loss of control. Good news was all though Lisa was face down for almost 2 hours, it was still dry inside, so nothing was damaged. My battery showed 2.58 volts on both cells but it took 4000 mah ( in a 2s 4000 mah battery) and end voltage was 4.20 volts on one cell and 4.19 on the other. I haven't used it yet, but it seems OK.
I think I'll try to get an aluminum servo arm ! It was a pain to retrieve, but I'm glad I got it back ! It's to much fun to lose !
If anyone else is using a plastic ( nylon, whatever ) servo arm, check it over for cracks !
Happy surfing !
Happy surfing !
#2413
HI
RE: RC Surfer
Kevinmham
unreal story good thing you got it back , i allways bring my surfboard with me when i go rc surfing. but just the other day i forgot it and my guy died so i had to swim for it good thing the water is warm.
john maui
john maui
#2414
RE: RC Surfer
thats sounds hellish kev good you got it back, ive had to do the scramble over sharp rocks swim thru rocks etc had cuts all over me, but got the b@#$% back. gonna go check my servo arm now thanks man.
now its been rebuilt. and its f'n sick had first surf test this morning stayed dry and just kept going i got no idea hhow long run time was but i just kept thinking this has gotta die soon, this has gotta die soon and just kept goin, im pretty happy right now just waiting for batts to recharge, this time i will time it.
so worth the effort
still cant sort the utube vid issue but will hopefully get vid up later
so worth the effort
#2415
CA
RE: RC Surfer
Thank you Thank you Thank you Thank you Thank you Thank you Thank you Thank you Thank you Thank you Thank you Thank you Thank you Thank you Thank you Thank you Thank you Thank you Thank you Thank you Thank you Thank you Thank you Thank you Thank you Thank you Thank you Thank you Thank you Thank you Thank you Thank you Thank you Thank you Thank you Thank you Thank you Thank you Thank you Thank you Thank you Thank you Thank you Thank you Thank you Thank you Thank you Thank you
Curly!!
I cant wait to build this thing!!
Curly!!
#2416
Banned
RE: RC Surfer
That Appears To Be Some STOKE ! Thats what it's all about.
I know all the builders and rc surf pilots that follow this forum agree on that ...
You'll have the Kyosho hull soon. Going out Tomorrow.
P.S. Hello Jimi. No Word For Awhile ( Too Long)
Hope All Is Swell ...
#2417
RE: RC Surfer
Alien,
Where are the pics or vid of Lolo and your boards in action?
We have already seen plenty of pics of Lolo's cool boards before.
What about some actual surfing shots???
Kev,
What a mission!
I recommend you take a surfboard!
Sooner or later you will need to rescue the little Dude again.
Maui and Stonky,
Looks like you guys had a great time.
I love the little yellow rocket.
How do you cram everything in so tight?
Flashlight Curly,
How are those drums comin' along.
Cananzi,
I checked out your vids.
Good to see your board is runnin' well, nice carvin' bro.
I'd say you know your stuff on the axe.
Get into a bit of metal do we???
Rainer,
Any new pics bro?
How did the tail mods effect your boards performance?
Fish,
Sounds like you have created a monster.
Can't wait to see some pics or vid.
Sea ya guys.
JIMI
Kev,
What a mission!
Maui and Stonky,
Flashlight Curly,
Cananzi,
Rainer,
Any new pics bro?
Fish,
Sea ya guys.
JIMI
#2418
Banned
RE: RC Surfer
The Drums Are pounding Brighter Than A Lipo Filled Search light.
How Do YOU Like The New Transmitter ? I have heard some mixed response
Outside of The Forum ...
Man Your Fast !!!
Man Your Fast !!!
#2419
RE: RC Surfer
new board is sick just got back from 2nd surf.
with 3.4v cutoff she ran for 31 mins and should get better when cells are run in. that was with y531 prop.
motor was a little hot but esc and batts only slightly warm.
u tube is peeing me off 45 mins off uploading last night to get upload unsuccessful message with no reason. anyway only got flat water footage from 1st test as was on my own today, hopefully wil get it up tonight.
it was a good day
later
it was a good day
later
#2420
RE: RC Surfer
HI all
Hopeful a quick one you guys can answer i need the measurements for the placement of the dude on top of my board
so from the nose to the front foot etc...
Daniel Hicks
Daniel Hicks
#2422
RE: RC Surfer
dan 355mm from nose to centre of peg hole give or take a few mm or i turned lid upside down and measured from the front of lid to peg hole 168mm thats a nqd lid.
#2423
HI
RE: RC Surfer
fish
all your hard work really shows in your vid . great job ,i notice you have to be lite on the tirgger when you start off ,your run time in the waves will be longer because you cant use your trigger as much unless the waves are 10 feet . john
#2424
CA
RE: RC Surfer
Well..........I got the original brass motor cooling coil cleared out finaly. Not easy, I boiled it then froze it then hit it with a sand blaster. It seamed to work fine. I replaced the old 19T Chameleon with a 17T Radon it was cheap and my brushless system had not arrived yet. So I dropped in a Orion Rocket 3500 2 cell LiPo from one of my cars its a newer battery and works great. I was running the thing in the harbor at Dana Point just to check it out. It was windy and to choppy outside. So I'm buzzing around..the thing is bouncing at more than 1/2 throttle and I'm thinking about adding to the rear edge of the board like a trim tab to hold the nose down a little. I had a NiMH battery that is heavier so I go to switch batteries and the LiPo is PUFFED!!! CR@P!! That was a $40 battery. So I switch batteries and it is still bouncing like a ****.......I run until the MH slows, and as I'm opening it up I notice the endbell on the motor is melted!! WOW bad day.
#2425
RE: RC Surfer
Justin-san
Too bad about the battery , man, it sucks when that happens. My latest battery is an orion rocket pack as well. I'm using a 2s 4000 hard case in my board and am very happy with it. It's the same pack I drained to far earlier this week. Tried it out today, and it worked great ! Yours might be salvageable as well. Good luck
