Springer Tugs
RE: Springer Tugs
ORIGINAL: foodstick
Nice work, If I am seeing it right you pulled a mold, poured a clear type piece which is illuminated completly from the inside, then you paint out the NON lit areas around the guages. that is definately easier than multiple light sources. And will look great when its up and running.
Now I need a flat panel monitor, but I am not sure if I want a one off, or should cast that up. [&:]
RE: Springer Tugs
ORIGINAL: foodstick
Umi, maybe a monitor made from the display screen of an old throw away cell phone?
cheap 1.1" diagonal? photo key chain display. [>:]
Maybe it will be able to display this...
Here are the flat panel monitors I worked up...
