traxxas engine Xpower
I always compare apples to apples, such as (1) $125.00 engine against another $125.00 engine, as the traaxas 2.5 and 3.3 engines have some thing very unique about there design which is something I have observed in only (3) other engines my question was to see if anyone else had observed this in the traaxas engines mentioned above?
Moby
Moby
CA
Moby
Moby
Vapor lock? In my many years of being apart of the small engine hobby, I have witnessed hundreds of different engine brands with,"carb related vapor lock simply due to, "operator error"
Rod tends to break? This one is very easy to explain, pick the engine brand, and or size, .049,.051, 090,.12, .15, .17, .18, .19, .20,.21,.25, .26,.27, .28, .29,.30, .35, .36, .40, .45, .49., .60, .61, .65, .67, .69, .77, .80, .84, .90, .91, .94, 1.00, 1.01, 1.10, and I have personally seem rods break on all these engines due to, "operator error".
In regards to the original question regarding the Traaxas 2.5 and 3.5 engines Xpower, and also having a unique manufacturing design, these engines are both a long stroke and a short stroke engine.
Consider yourself enlightened!
Moby
CA
Since U brought up [2} items that were not part of the original question, I shall address these first.
Moby
Moby
I'm not enlightened. I'm mystified how anyone could make such a claim. There is nothing unique about their design.
When designing an engine there are a whole plethora of options. High performance engines in general use higher grade materials and manufacture.
How would I go about making an existing engine more powerful? Alter the timing...lighten components...change the pipe....change the fuel...change the plug...change the head clearance/modify the button.
Moby
Regarding my post "traaxas 2.5 and 3.3" engines that are both a "long stroke" and a "short stroke engine, if U have not studied these engines enough to have all of the data on these 2 engine parameters, that would explain why u are mystified. What I have posted about these engines is not just a claim, or something I made up, it is something very easy to understand when U have all the data at hand.
Moby
BTW, many years ago a man named duke fox, released a new control line 36X engine for slow and fast combat that was also a "long stroke", and a "short stroke engine", no claim, just facts!
CA
You replied that U "disagree" with my post regarding "operator error", as to what causes carb vapor lock and rod breakage. Perhaps U can explain why U disagree and what data U are using in your conclusions.
Moby
Moby
One of my first RC engines was the TRX. After it broke a rod during break in, I researched the problem. Rod breakage can be caused by user error, but the shear mass of TRX breakages was discussed on all the forums. Sorry you missed it. The problem even prompted Davis diesel and others to produce HD TRX rods.
Anyway it's clear you're a Traxxas fanboy. That's cool. I'm not. Enjoy the cool-aid. I'm out.
The 3.3 engine has a 15.1mm stroke and 16.8mm bore which makes it a bit over square and a short stroke engine. The 2.5/R has a square bore/stroke ratio at 14.75mm each.
The 3.3 is a short stroke engine and typically this means its a low-mid rpm engine as compared to the 2.5 which is not a short stroke or a long stroke engine. I don't have the exact figures in front of me but the 3.3 is timed a little better than the 2.5, roughly 153* in the 2.5 and 167* in the 3.3. I can double check later but it doesn't really matter much IMO.
Last edited by 1QwkSport2.5r; 04-26-2014 at 11:54 AM. Reason: Added more accurate specs.
The 3.3 engine has a 16.9mm stroke and 14.7mm bore which makes it a bit over square and a long stroke engine. The 2.5/R has a square bore/stroke ratio but for the life of me I cannot find the actual bore and stroke.
The 3.3 is a long stroke engine and thus a better breathing engine as compared to the 2.5 which is not a short stroke or a long stroke engine. I don't have the exact figures in front of me but the 3.3 is timed a little better than the 2.5, roughly 157* in the 2.5 and 168* in the 3.3. I can double check later but it doesn't really matter much IMO.
Moby
You want to know how to make an engine more powerful...but I have to think of something other than the things I have already listed and I am not allowed to change anything?
h
Anthoop
I would agree with your post, "add more nitro to the fuel", however this was suggested in post #10. I was asking as an informational thought process on the quick and easy way to increase horse power with a quick and simple changing to a larger carb.
I am posting some engine data from my software program on the traaxas 3.3 engine, a lot of numbers to look at, the time study is great for understanding what actually takes place during 1 complete revolution, and how fast every thing happens..
Moby
Date 03 21 2011
engine Traaxas 3.3
serial # 321
practical RPM 31000
engine bore 0.665
engine stroke 0.578
rod length C to C 1.118
max rod angle 15.0
exhaust swept 0.428
exhaust duration 159.6
boost intake duration deg. 115.1
boost swept stroke total 0.522
transfer swept stroke tot. 0.501
head clearance in. 0.015
head volume cc 0.19
compression ratio 9.3
rotor open in.tol/top 0.587
rotor open degrees ATDC 216
rotor close in. tol/top 0.250
rotor close deg. ATDC 65
rotor duration degrees 209
timestudy @ 31000 RPM in seconds
exhaustexchange time 0.00086
intakeexchange time 0.00068
rotorexchange time 0.0113
optimalcarb size in. .321
Moby
Date 03 21 2011
engine Traaxas 3.3
serial # 321
practical RPM 31000
engine bore 0.665
engine stroke 0.578
max rod angle 15.0
exhaust swept 0.428
head volume cc 0.19
I have included my engine analysis info for the 3.3
moby
Date 03 21 2011
engine Traaxas 3.3
serial # 321
practical RPM 31000
engine bore 0.665
engine stroke 0.578
max rod angle 15.0
exhaust swept 0.428
head volume cc 0.19
exhaust exchange time 0.00086
intake exchange time 0.00068
roto rexchange time 0.0113
optimal carb size in. .321
Two things. First, you shouldn't post the same information in two posts in a row. Second, I couldn't pull my own engines apart to measure them so I was going off of specs I sourced from the often wrong internet. I measured my own engines before posting this. I'll edit the specs I posted previously to reflect the closer figures I obtained today.
The 2.5 has a 1:1 bore/stroke ratio at 14.75mm(.580") each approximately. The 3.3 is over-square with a bore/stroke ratio of 1.10:1; the bore is 16.8mm(.660") and stroke is 15.1mm(.590") approximately. What separates a long stroke engine from a short stroke engine is the bore/stroke ratio. Bigger bore than stroke = short stroke; smaller bore than stroke = long stroke. So my previously posted specs for the 3.3 are wrong; it is a short stroke engine which would lend it to be a low-mid rpm engine. I did not figure the head clearance in because I didn't have time.
2 engines can have the same rod but the wristpin height can be different as well as the fact the 3.3 uses a different crankshaft than the 2.5 to boot.
It's been shown through Dyno tests that the 3.3 makes around 0.9-1.0hp on 30% fuel. Making much more power is going to require some big timing modifications, compression adjustments, and cylinder head modifications at minimum. For the time it would take, you'd be better off buying a better engine.
Other than that, as said above, other alterations will give more power. Changing the carb. would only be necessary if it is inadequate/poor in the first place...and that I do not know.
moby
