Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > RC Car Engines
Reload this Page >
Pin lining up piston sleeve gone??? HELP...
RC Car Engines Talk about rc car nitro engines and gas engines
Old 12-07-2014, 04:23 PM
jlong2214
Default Pin lining up piston sleeve gone??? HELP...
As you can aee i have a problem my pin for algining my piston sleeve is gone and idk where it is. What do i do now??????
Old 12-07-2014, 05:50 PM
downunder
downunder's Avatar
It's not too much of a problem unless it fell down into the crankcase when you were removing the liner. I'd check that fairly carefully before you put the liner back in. Otherwise you can eyeball the alignment or use a close fitting drill shank or wire to guide the liner into position.
Old 12-08-2014, 07:36 AM
1QwkSport2.5r
1QwkSport2.5r's Avatar
Or just line up the exhaust port of the liner with the exhaust port in the case. The exhaust port is the highest port in the liner.
Old 12-08-2014, 01:10 PM
Anthoop
Anthoop's Avatar
...and once it is lined up tighten down the head...job done.
