RC Car Engines Talk about rc car nitro engines and gas engines
Big red .28
Reply
Old 11-21-2017, 11:49 PM
O5ive
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Big red .28
Hey guys
I just installed big red .28 engine in my savage. The engine starts fine but as soon i remove the glow plug igniter the engine dies. Already leaned out the lsn..any clue what I'm doing wrong? Any help would be great. Thanks
O5ive is offline
Old 11-22-2017, 05:30 AM
1QwkSport2.5r
1QwkSport2.5r's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If you've run several tanks through it to break the engine in, wear particles from breaking in (or swarf) will cook the plug. Try a new plug. If the problem still exists, the low speed is still too rich. Remember - the idle mixture needle is only used to control mixture at idle and *just* off idle only. If the rpm ever drops or the engine quits with the glow driver disconnected but runs steady with it connected, your idle is too rich. When buying replacement glow plugs, only use long reach plugs and ideally a medium heat range.
1QwkSport2.5r is offline
Old 11-22-2017, 01:01 PM
rgburrill
rgburrill's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Originally Posted by O5ive View Post
Hey guys
If leaning doesn't work go the other direction.
rgburrill is offline
Old 11-22-2017, 06:14 PM
O5ive
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks guys. Glow plug was an issue and I adjusted the needles back to default and it has been working pretty good. 4 tanks down.
Another issue I noticed my throttle on the remote loses signal no response but the steering works just fine not sure if it's the antenna or the servo itself. Any guess would be a good start.
O5ive is offline
Old 11-22-2017, 06:38 PM
1QwkSport2.5r
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Servo or receiver. If one channel works and the other doesn't, it's the servo or receiver. Check servo first with a known good one.
A lean needle is a lean needle. An engine will not stay running with the glow driver connected any better than without if the needle is too lean. It will if it's too rich.
Old 11-22-2017, 08:20 PM
O5ive
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Servo seems to be ok. I think it's the receiver.
O5ive is offline
Old 12-24-2017, 02:42 PM
mkjohnston
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
What type of battery do you have in you Vehicle? If its just 4 AAs in a battery holder there is your culprit. You need a 6v mini c Nihmi battery and charger to run the radio properly and also get a throttle return spring on the throttle because sometimes your battery craps or it comes unplugged and you a have a runaway on your hands! My @ cents Merry Christmas and A Happy New Year!
mkjohnston is offline
