RC Car Engines Talk about rc car nitro engines and gas engines
Clutch issues, HELP!!
Old 07-29-2016, 09:40 AM
Xenon Paradox
Exclamation Clutch issues, HELP!!
Hello friends, i currently am having an issue with my Kyosho Inferno ST RR's Clutch. at a race last weekend my shoes finally decided they had enough, so i just changed them this morning! as i pulled the old shoes off i noticed the fly wheel nut had backed out abit. so i re- tightened it and installed the new shoes. upon re installing the engine into the car everything seemed okay BUT, when i went to spin my wheels and see if the gearing lined up, i noticed that neither the clutch bell or the drive wheel moved. i proceeded to start the car. and at idle the wheels kept spinning (off the ground) as soon as the wheels hit the ground the engine died... it also dies when i apply the brakes. and when the car is off, it doesnt roll, the wheels stay locked! PLEASE HELP!
(it seems that Neutral doesnt exist anymore)
thanks!
Dan
Old 07-29-2016, 10:42 AM
1QwkSport2.5r
1QwkSport2.5r's Avatar
Your clutch spring isn't installed correctly or broken most likely. Remove the clutchbell and check to ensure the shoes are installed correctly and the spring(s) is/are attached correctly. Reinstall the clutchbell and give it a spin. It should spin freely. If it doesn't, then there is still an issue with the clutch. Also, when you tightened the flywheel but - did you ensure the collet was installed fight against the front bearing and the crankshaft was pulled forward (towards the front of the engine)?
Old 07-29-2016, 11:49 AM
cbaker65
cbaker65's Avatar
thanks!
Dan
You've probably tighten the nut up against the clutch bell bearing ,you may need to buy a clutch bell bearing thrust washer kit
which is only acouple bucks.
Those are shims so the clutch nut doesn't tighten up on the bearing!...
Old 07-29-2016, 12:39 PM
Xenon Paradox
i checked it out and it turns out that the rear bearing closest to the shoes wasnt shimmed correctly. 7.99$ fix =)
thanks for the tips!
Old 08-24-2018, 11:13 AM
Rcjunky81
Check if your springs are good
