RC Car Engines Talk about rc car nitro engines and gas engines
kyosho mad crusher engine ke25sp
Reply
Old 06-14-2019, 06:26 PM
meister1993
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default kyosho mad crusher engine ke25sp
im new to kyosho engines I usally do os engines what are my options with glow plugs ke25sp engine thank you
meister1993 is offline
Old 07-04-2019, 06:56 AM
mugeyman
mugeyman's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
hi meister , you should use same type glow plug that came with kyosho ke25p weather it be a standard taper type plug which sets flat or even in head or a taperd turbo type plug which sits deeper in to the head and extends into the cylinder bore ( you do not want to break anything internally ) piston , glow plug wire than engine is can be destroyed ok there are a few manufactures for a replacement glow plugs
os engines , novarossi , werks mcdonnell hope i helped ok mugey
mugeyman is offline
Old 07-04-2019, 07:51 AM
1QwkSport2.5r
1QwkSport2.5r's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The OPs question was asked in several different threads on multiple forums and answered in several different threads on multiple forums. The reality is the company that made the engines is no longer in business, so you won’t be able to find parts for it soon. Another reality is the best brand of plug to use is often one carried locally as this makes it easier and cheaper to get. Otherwise if one has a favorite, buying online is best.
If your engine is designed to use long reach glow plugs, use long reach plugs. If it’s designed for
mid reach Japanese plugs, use those. Enya is the only one I know of that actually takes the mid reach plugs. OS standard plugs are shorter than long plugs but longer than short plugs. When the plug is proper for the engine, the base of the glow plug will be FLUSH with the top of the combustion chamber. If the plug is recessed, you’re throwing away power and risking some tractability.
Heat range- I always recommend to start with a medium heat plug for bashing. Hot plugs end up being less efficient to use as they often are improperly tuned to and consequently use more fuel. Colder plugs give more power over hot plugs, but the colder you go, the lower the idle quality may be. Not a big deal for a seasoned tuner, but the novice will have better overall luck with a long reach medium heat plug. Novarossi C6S, McCoy MC8, Picco P6S are great standard plugs. For turbo plugs, I’d recommend Picco P6TH or Novarossi CTO6/C6TGC. I prefer their quality over the other brands although O’Donnell has been said to have very good plugs with the same taper as Novarossi plugs. When you pick a brand of glow plug to use in a turbo plug engine, use the same brand all the time. Some heads have slightly different tapers and once they deform the head, they may never seal properly again.
Enough of my ranting. Hope this helps someone out.
1QwkSport2.5r is offline
