Adjusting front end
Adjusting front end
Hello,
I am a newbie to the RCworld. I just got a Traxxas slash ultimate 4x4 truck. Need advice on general maintaince, and adjusting the front alignment. in running straight it pulls to the right. What do I need to adjust to correct this pull and run straight?
Looking forward to getting into RC trucks!
RE: Adjusting front end
When you say you just got it, I am assuming that it is fresh out of the box. If that is the case then the alignment is probably ok. On your transmitter there is an adjustment for steering trim. Give that a little tweek and let us know how it turns out.
Hope that helps.
Vic
Hope that helps.
Vic
