rc 10
rc 10
hi people im new here so take it easy on me. i got an old rc 10 and was interested into getting it running again any help or ideas would be great. maybe brushless would be cool i dont know thats all new to me also some battery info would help. like do i want to go to lipo batteries or get some new nickel batteries what do you think?
RE: rc 10
Thats a nice vintage collectable, might wanna make it a shelf queen.
But its all in what you want to do.
Does it have the stealth transmission on it ? if it does it will probally hold up to brushless
and li-po...but check it out first!
RE: rc 10
I have a gold pan also. Thinking that it would be fun to drop a brushless/lipo setup in it. Wouldn't win any races {not really the cars fault } but would be a cool piece.
RE: rc 10
also the old radios i got do you think that i might need to upgrade them or do you guys think that there still good i got an old futaba magnum. and you guys think the servoes would still be good.
RE: rc 10
ORIGINAL: winkjr
Id say the servos are fine too, just put some fresh batts in the radio and try the servos out.
RE: rc 10
ORIGINAL: winkjr
how would i know if the rc 10 has a stealth transmission
RE: rc 10
The 6 gear transmission is kind of designed weird, instead of having a diff down inside the transmission... its up at the spur gear. Each wheel is driven by 3 of the 6 transmission gears. You really have to take it apart (or find a diagram) to fully understand how it works. Now keep in mind, Associated did make a white stealth transmission for a while, but those are pretty rare.
Here are both the transmission cases. The first is a 6-gear, the second is stealth. Just compare them to yours. If you plan on running brushless, you would need to rebuild it anyways. Just count the gears inside.
RE: rc 10
I've got a vintage gold pan rc10 too! It's great, all the same electronics and radio! It runs like a charm still! That's why I got back into the hobby bc after all these yrs it's still running! That's intriguing! Good luck with yours. I still have orig motor but for fun I slapped in a new venom motor and the thing flies! Cool stuff!
RE: rc 10
i guess now the only issue i would have is batteries im not to up on the lipo stuff or should i just go buy some new nickel batteries. everything looks so different then when i was into it.
