Running the tank dry
NC
I just got my nitro Rustler and i was wondering if it is bad to run the tank fully dry rather than pinching the fuel line before its out?
Re: Running the tank dry
I don't think that it hurts the engins at all(they usually tell you not to do it during a breakin). I have been doing it for about 5 years and I still have the same engine in my RS42.
I usually just put my finger over the exhaust stinger for a second. (whatch out some times is burns) when I want to shut the car off.
Originally posted by Smalls
Actually, I use the pinch test to check on tuning also. Nothing wrong with running the tank dry. It happens all the time.
Watch it kids!!
I dont think theres anything wrong with running out of gas.
BUT.. there is a catch.
Your engine is running on very little fuel (AND OIL) so your car will be slightly harder to start the next time around (possibly).
On the other hand, choking the engine by putting your hand on the stinger may flood your engine and also making it hard to start.
the easiest way I've seen is:
Just hold your car and stick your shoe's heel on the flywheel!
Heck I've seen people stop the motor by stopping the flywheel with their FINGER ! I'm too much of a wussy to try that but I do it with my shoes and it works well.
Ram
Ram
Originally posted by William H
I was told to run all of the gas out is that ok or is that what I am supposed to do?
For real? I'm kinda scared because last winter... my car went out of control, and while it was full throttle.. my finger touched the flywheel.
Yes.. it hurt. I'll stop there.
I have bad memories from touching the flywheel lol
ram
ram
GA
ram
ram
AZ
My car got stuck at full throttle in my hand once (I was an idiot, still am) and my knuckled nabbed the spur gear while I was going for the fuel line, all I can say is it was messy.
ram
ram
As for letting the tank run dry, that fine, its pretty much the same as pinching the fuel line. I would not recommend putting your finger over the pipe for 2 reasons. 1 it can burn you, second it doesn't clean the engine out of fuel, which isn't good to be in the engine when its not running. Also, you should not shut off the engine by restricting air flow, one because again it doesn't burn fuel out of the engine, and secondly it may push particles into the carb if you squeeze the air filter. The best way is to either let the tank run dry, or pinch the fuel line. That 3 seconds of running lean will not hurt your engine.
NC
A little hint and piece of mind.
Running a tank dry or pinching the line DOES cause an instant lean condition starving the engine of fuel as well as lubricant (oil) (as "buggies" pointed out).
Go to your local auto parts store and pick up some Marvel Mystery Oil. You can add a little to your jug (gallons or what have you) or a few drops per tank upon refill of your car/truck. An eye dropper works well with tank mixing. It's a crankcase/bearing lube, a top cylinder lube and will never gum up. It's great for winterizing or when you run your tank dry. Starve your engine of fuel if you need to but don't sacrifice the life.
