How are R/C car tires made?
Reply
Old 05-25-2011, 11:33 PM
stoya789
stoya789's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default How are R/C car tires made?
Looking for any links or articles demonstrating how they are made. From machining the molds to rubber compound injection.
stoya789 is offline
Old 05-26-2011, 02:33 AM
lez1troubles
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: How are R/C car tires made?
very carefully.
lez1troubles is offline
Old 05-26-2011, 02:37 AM
ThunderbirdJunkie
ThunderbirdJunkie's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: lez1troubles
very carefully.
Unless you're JConcepts, then you make them haphazardly, with no quality control, and reckless abandon[8D]
ThunderbirdJunkie is offline
Old 05-26-2011, 04:30 AM
lez1troubles
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
sounds like they could be fun then.[:@]
Old 05-26-2011, 10:55 AM
378's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: ThunderbirdJunkie
very carefully.
Tamiya and CEN make good tires too. The tires on my MT2 are the originals, have about three gallons on 'em, and they look brand new if you spit shine them. The rally tires I bought for the car are Tamiya's, and they're wonderful.
Also, neither tire needs a foam, so I need not worry about mud/snow/water offsetting wheel balance.
378 is offline
Old 05-26-2011, 11:17 AM
electricrc68
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
they use a manufacturing plant with chimneys. then their machines make a ton of them a day.
electricrc68 is offline
Old 05-26-2011, 11:18 AM
SyCo_VeNoM
SyCo_VeNoM's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: 378
very carefully.
Still got 11yo proline dirthawgs those things seem to never lose thread
I got the set on a extremely used, and abused MT1 ran em a bit on my MT2, broke a rim, put em on a new $5 rim set(they were on clearance at my LHS originally marked $20), then slapped them on my electric MT1 I made, then after that was dismantled slapped em on my DF-02 turned ST where they sit to today.
In all honesty they still look like new, I have a pair of brand new ones I got with a RC roller (guy never glued em or anything) that look the same as those.
SyCo_VeNoM is offline
Old 05-26-2011, 11:39 AM
378's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: SyCo_VeNoM
Quote:
ORIGINAL: 378
very carefully.
Nice. The Tamiya Rally Blocks do have a bit of wear on 'em. The outer shoulder is ground away. But that's because the body rubs on them at full compression, and there's nothing I can do to fix that short ruining the body, so I just shrugged and let it grind the shoulders off. It has since stabilized, not grinding into the carcass itself, so they're not likely to come apart.
378 is offline
Old 05-26-2011, 09:58 PM
lez1troubles
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Medial pro make good tyres also.
Old 05-26-2011, 10:48 PM
tommygun32
tommygun32's Avatar
Location: San Diego but living in Dubai, UNITED ARAB EMIRATE
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have no idea stoya, I've looked all over for a link or answer and I haven't found one that gives you all the actual info on how tires are made. It's probably more of a trade secret and won't be posted on the net for everyone to see. [:-]
Quote:
ORIGINAL: stoya789
tommygun32 is offline
Old 05-27-2011, 03:27 AM
FahrtAutoRC
FahrtAutoRC's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I would imagine they are made by an injection molding process, seeing as how they make X amount of the same tire day in and day out they probably just used a fixed automation process and keep fillin' the molds!
FahrtAutoRC is offline
Old 05-27-2011, 06:34 AM
SyCo_VeNoM
SyCo_VeNoM's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: HimmlerHimself
that would be my guess seeing they all look identical too, and have nothing special in them to hold them together like automotive tires do
Old 05-27-2011, 08:30 AM
Noff
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
RC tires are not injection molded. Simply put, the process is like this:
The mold is sprayed with mold release. The rubber is weighed and placed into the press mold. The shape and size of the rubber doesn't matter as long as the piece or pieces will fit inside the mold - only the weight/volume just has to be correct. The molding machine slowly presses the mold halves together while heating the rubber (to liquify it) and it flows into the mold cavity. Then the heat is turned off and the rubber is cooled so it solidifies again. Cycle time is anywhere from 3-6 minutes depending on the size/volume of the tire. Typically a mold has several cavities in it so you can make several tires per cycle. Typical is 2-4 tires per cycle.
Rubber molding is a stinky, dirty process and I suspect it's not terribly good for your health but I've never seen the machine operators wear breathing protection or protective outerwear ...in China at least, where most RC tires are made.
Noff is offline
Old 05-27-2011, 11:45 AM
FahrtAutoRC
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Close enough, dude.....
Quote:
ORIGINAL: Noff
Old 05-28-2011, 02:53 AM
stoya789
stoya789's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Noff
I always thought the tires were injection molded. Isn't what you just described basically injection molding? You mention liquifying rubber and having it flow into the mold cavity... Anyways, on one of my Team Associated RC10 buggy tires you can see 2 marks, one on each opposite end of the tire, I assumed these 2 marks were a "gate" and a "vent" which are typically used in injection molding. By the way, where did you get your information from?
stoya789 is offline
Old 05-28-2011, 09:19 PM
The_Shark
The_Shark's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
must be made from 30% gold because they are very expensive.
The_Shark is offline
Old 05-29-2011, 07:26 AM
The Mad Modder
The Mad Modder's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It's interesting how full size tireas are made.
http://www.youtube.com/watch?v=K474RYse9P8&NR=1
Actually I have seen some tires that are belted. I don't think any have beads, though.
http://www.hpiracing.com/products/en/103337/
The Mad Modder is offline
Old 05-29-2011, 07:27 AM
magnus213
magnus213's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The described process, which sounds correct, is the same as injection molding.
On slicks you can see the parting line running down the center of the tread surface.
magnus213 is offline
Old 05-29-2011, 08:10 AM
SyCo_VeNoM
SyCo_VeNoM's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: The Mad Modder
yea after I made that post I thought about the belted ones
I'm guessing those are made more like automotive tires
Old 05-29-2011, 12:44 PM
rasper
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
http://www.aliexpress.com/store/9055...og=minisite_CI Yuyao Inheritance Plastic Industry Co., Ltd.
contact these guys, and ask them. Tell them its for a school project or something and ask the how they make it. They also make rims and lipo batts., This is just a sample of what they can make....
rasper is offline
Reply
Display Modes
