Savage half tank EXTREME lean problem.
MI
RE: Savage half tank EXTREME lean problem.
ORIGINAL: 378
It will be down on power, it will be making strange popping noises,
MI
ORIGINAL: 378
I'd say it was on the edge of detonation, but it wasn't in full blown damaging the engine detonation. Nothing you need to worry about.
I got the fuel tank on and while I was at it changed all the fuel lines so hopefully that helps. Though, its raining right now so I can't go try it out. Bought some Ofna throttlelinkage that my friend has been bugging me to install on it so maybe I'll do that.
378, On a separate note,that GST 7.7 Iasked you aboutdidn't work out. I asked the guy 3 times how he broke it in. The 1st response was that he used Traxxas fuel. The 2nd response was that he just ran 20 tanks through it. And the 3rd time he just didn't respond, so oh well. I found a really nice, heavily upgraded Savage XL that made me lose sleep thinking about it, so I may just pick that up tomorrow.
ORIGINAL: 378
Now, preignition is different. It's usually caused by too much oil, improper timing/porting, too hot of a plug, and the wrong compression ratio. Preignition makes the engine sound raspy, lean, and a bit louder then usual. There really isn't a noticeable power loss, as it happens in the upper rpm bands. Preignition is hard on plugs, and can lead to detonation... which can be a real pain in the ass to figure out.
Pre-ignition is the edge of detonation. It's not hard enough to damage the engine, but it's a sign the engine wants to start misfiring, and if it isn't checked and corrected it will soon go into full detonation, which will damage it.
Guess we're just using two separate terms to describe the same thing. [&:]
#31
MI
Had it running with the 2nd tank and theOfna linkage but 2 minutes into the run my spur gear stripped out (unrelated- its been needing to be replaced for some time now). Will have to try again on Monday.
-In those 2 minutes, though, it seemed to get enough fuel, but no telling if it will work until I can run a whole tank. How much will the 2nd tank affect my tune?
