If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 17 of 17
  1. #1
    Join Date
    Apr 2011
    Allentown, PA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    engine heater
    Has anybody had any experience with the "Nitro Quick Heat" engine heaters?
    Do they actually work? I guess it's a sleeve that goes around your engine to warm it up before 1st start.
    Thinking about getting one but not sure. Any help?
    Thanks!
  2. #2
    proanti1's Avatar
    Join Date
    Dec 2004
    Boerne, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: engine heater
    No need, just use a hair dryer. You really only need to preheat engines with super high compression, and strong pinch.
    Her name was Lola. She was a show girl.
  3. #3
    Join Date
    Mar 2007
    Quakertown, PA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: engine heater
    I love um. I have a good buddy who's on this forum. Who makes
    Um. U don't have to stand there and hold it over your motor.
    U put it on and keep wrench n on ur other trucks. And in
    5min. Ur motor is warm and ready to fire up. Great for those
    Cold mornings. I get one. And he sells them at a great price too.
  4. #4
    1320Fastback's Avatar
    Join Date
    May 2008
    Northern Occupied Mexico, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: engine heater
    If your motors hard to start when cold just loosen the glow plug a little.
    This will bleed off some compression until its running and then simply tighten.
  5. #5
    Join Date
    Aug 2009
    bethlehem, PA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: engine heater
    every time you cold start a motor you put extreme stress on your internal parts ie.bearings,con rod ,wrist pin and piston.
    If you want your motor to last and keep its compression longer  you NEED to preheat your motor in cooler temps.
    loosening the golw plug is NOT the answer.
    ask ANY pro mechanic or engine modifier and they;ll tell you they use a engine heater!
  6. #6
    Join Date
    Mar 2007
    Quakertown, PA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: engine heater
    I used one of Pigpen's heaters, they work great..hooked it up to a bump box battery, and instant heat...don't need to have a generator. just 12v.dc
    Preheating is the way to go...good quality too. Thanks Pigpen
  7. #7
    1QwkSport2.5r's Avatar
    Join Date
    Oct 2006
    Cottage Grove, MN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: engine heater
    I keep my RC trucks in my house, so if I'm going to run outside when its cooler out I just get them filled up and primed in the house so they pop off right away outside. They dont even have a chance to cool off.
    I have never needed to heat an engine to get it started. Brand new or otherwise. I see no reason for an engine heater. Sounds like snake oil to me.
    Even if its 45Β°F outside, I can usually get an engine to fire just fine. Below that and it sits inside the house for 10 minutes. thats just me though.
    GlowHead Brotherhood #3
    Real engines use glow plugs.
    R.i.P Jacob Wetterling #11 10/22/1989
  8. #8
    Join Date
    May 2008
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: engine heater
    Maybe "race" motors are tighter or maybe being in SoCalif keeps them a little looser being 70 degrees in the winter.
    Even my 1:1 classic diesel truck doesn't need the block heater to start here.
  9. #9
    Join Date
    Apr 2011
    Allentown, PA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: engine heater
    thanks for the advice guys!
    I think I'm gonna get one cuz when we race
    (depending on the season) it gets pretty cold here.
    I've got a slammin' JPX.21 that I don't want to ruin.
  10. #10
    supertib's Avatar
    Join Date
    Mar 2004
    , MB, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: engine heater
    engine heaters are awesome....
    Neal Smith..Owner of TheNitroShop www.thenitroshop.com
  11. #11
    Join Date
    Dec 2009
    city
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: engine heater
    in my old inferno 10 i had an OS12 that was on its8 th or 9 th gallon before i sold it and never once did preheat the engine and it never gave me any issues.
  12. #12
  13. #13
    378's Avatar
    Join Date
    Jan 2004
    Lebanon, TN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: engine heater
    ORIGINAL: pigpen1
    If you want your motor to last and keep its compression longerΒ* you NEED to preheat your motor in cooler temps.
    I disagree. Just store the car inside. It's not difficult and they don't make a mess if you don't let them. When you're ready to run, get it primed and ready to start indoors, head outside, pop the ignitor on and give it a couple yanks. Bam. Running.
    No need for a block heater with our RCs.
    My stash:
    1 rally modded NTC3, 1 HeliMax Axe CX Nano, 1 Hobbico NexSTAR, 1 1/35th scale KV-2 model turned RC, 1 Tamiya Grasshopper, 1 1/16th Tiger I(In progress).
  14. #14
    Join Date
    Nov 2011
    allentown, PA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: engine heater
    you dont race do you 378 or know how an engine works do you!
    ORIGINAL: 378
    ORIGINAL: pigpen1
  15. #15
    saucySavy's Avatar
    Join Date
    Jan 2011
    Russell, ON, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: engine heater
    WTH? ^ I run nitro, were its at or below freezing for 60% of the year. I've never used an engine heater, i just do exactly as 378 said. My motors run great.
    How does this have to do with 'knowing how an engine works"? You remind me of how I used to talk when I was 13 years old, acting like I knew everything. You have 4 posts on this forum. If you want people to like you in the future, then play nice.
    Anyways I agree with 378. i just get them ready inside and fire them up as soon as Iget outside. Once they are running wrap them in foil and your good to go. the engine doesnt know the difference between winter and summer, or atleast not in my experience.
    Sweet Savage, Associated RC8, firestorm, 1/16 summit vxl
  16. #16
    The_Shark's Avatar
    Join Date
    Jun 2007
    Plainfield, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: engine heater
    FIRE!!!!!
    Signature
    (Max. 125 chars. 2 lines max)
  17. #17
    Join Date
    Apr 2011
    Allentown, PA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: engine heater
    well guys even though the racing season has ended here I got a "Nitro Quick Heat" engine heater anyway.
    ....I gotta tell ya....
    It's never been so easy to get my truggy started!
    I can see the advantage now.
    Thanks to Pennsystudios!
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
