Diff Oil Alternative
Reply
Old 12-25-2011, 10:57 AM
DriftingFast
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Diff Oil Alternative
My current kit that I am building seems to have not come with any Diff. Oil, but it did come with 3 other oils. Could any of these be another name for diff. oil or counld any of them work?
Ceramic grease
Molyboenum Grease
Damper Oil
If none of those work I have silicone-in-a-can (not WD-40, just regular SIAC) would that work?
DriftingFast is offline
Old 12-25-2011, 11:09 AM
DriftingFast
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Diff Oil Alternative
Ok, searching around I saw that the ceramic and the molybdenum grease are both for the differentials. Should I use one over the other?
Old 12-25-2011, 11:40 AM
proanti1
proanti1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Molyboenum Grease
Most entry level kits do not come with diff oil, they just want you to grease the gears. The ceramic grease is for outside the diff, for the ring and pinion. In your manual, it should tell you which grease to use. Each little bottle/container should have a part number on it.
proanti1 is offline
Old 12-25-2011, 10:28 PM
Shabbernigdo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: proanti1
Molyboenum Grease
in tamiya kits they usualy give you ceramic greas or moly for the gearboxes / diffs.
my cr-01 uses cernamic grease
tt-01 uses the moly
Tiger 1 uses the ceramic grease in its gearboxes.
Shabbernigdo is offline
Old 12-26-2011, 10:23 AM
The_Shark
The_Shark's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i use auto bearing synthetic grease for the inside of the gear box, and sil-glyde for the ring/input gears.
if its open i use just synthetic grease.
if its a small scale i use sil-glyde only.
to each his own.
The_Shark is offline
Old 12-28-2011, 08:06 PM
Smiff 24
Smiff 24's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey Shark, is this the lube your referring to ?
http://www.autozone.com/autozone/acc...ntifier=193245
Smiff 24 is offline
Reply
Display Modes
