Servo Horn Adapters
Old 03-10-2012, 03:29 PM
JohnP2
JohnP2's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Servo Horn Adapters
Today I started to install the Airtonics 94851 servo but the servo horns are completly different;, and Hyper 7 servo horn won't fit on the Airtronic's spindle. ;-(
So at this stage my choices are:
1. Find an adapter - I've seen this http://www.amainhobbies.com/product_...vy-Duty-Blackm but notice it does not say it is compatible with the Hyper 7. Anyone know of a sure-fire adapter.
2. Find another servo - My next choice would be the Hitec 5645MG. Can somene let me know who has one that it will DEFINITELY fit the OFNA Hyper 7 without any modifications?
Thanks!
JohnP2 is offline
Old 03-11-2012, 08:19 AM
proanti1
proanti1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Servo Horn Adapters
That servo horn kit should work, they include adapters for all the major brands.
JR/Spektrum/Airtronics - 23 splines
Hitec - 24 splines
Futaba - 25 splines
proanti1 is offline
Old 03-11-2012, 08:30 AM
DaveG55
DaveG55's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: proanti1
Hitec - 24 splines
Futaba - 25 splines
I agree, I've never seen one that could not at least be adapted. Sometimes I've had to trim a horn/adapter to fit a particular application though. Have you tried calling the Airtronics and asking them which one to use or how to make it work in your vehicle?
DaveG55 is offline
Old 03-11-2012, 08:58 AM
JohnP2
JohnP2's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks. Forgive me, however, as I am a bit confused.
Are you both stating that the servo horn on my Hyper 7 should fit onto the splines of the Airtronics servo? The problem appears that the servo horn "hole" (not sure what it's called) is a bit smaller than the splines, so it does appear to fit. Honestly, I did not force the horn down all too strongly on the servo, but can try again.
Or...are you saying I need the adapters (http://www.amainhobbies.com/product_info.php/cPath/1_25_1461_635/products_id/13634/n/OFNA-Servo-Horn-Heavy-Duty-Blackm )
Thanks!
JohnP2 is offline
Old 03-11-2012, 12:04 PM
DaveG55
DaveG55's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Are you trying to use the horn that came with the car, the one that was on the stock servo? If so, that may not be possible. If the stock one is not fitting then I'd use one of the ones that come with the servo and adapt it to fit the situation. I believe that the new servo comes with a wheel and a 6 arm horn?? I'd think that the 6 arm one could be adapted to fit. Maybe post photos of what's in the car and the new horns and we can give suggestions.
DaveG55 is offline
Old 03-11-2012, 12:13 PM
nitroexpress
nitroexpress's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: JohnP2
Thanks!
Just to make sure, you are aware that different brands use different splines, right?
23 spline: KO, JR, Airtronics/Sanwa
24 spline: Hitec
25 spline: Futaba but not micro.
nitroexpress is offline
Old 03-11-2012, 12:39 PM
JohnP2
JohnP2's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: DaveG55
Yes, I am trying to use the stock horn (single arm).
The Airtronics only came with a wheel. I tried to put the stock servo arm onto the wheel, but it won't fit.
ID:	1737574   Click image for larger version
JohnP2 is offline
Old 03-11-2012, 02:56 PM
proanti1
proanti1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You will need to order that kit, or stop by your local hobby shop and pick up a pack of Airtronics servo horns.
proanti1 is offline
Old 03-11-2012, 05:23 PM
DaveG55
DaveG55's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well, you might be able to make the wheel work. It's a bit hard to tell from the pics but the offset (center of wheel to center of hole used) looks close to the same. If it's pretty close then try the wheel. If not then, yeah, as proanti said, pick up a set of airtronics horns.
DaveG55 is offline
Old 03-12-2012, 02:32 PM
JohnP2
JohnP2's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks guys. At this point I think I will take it to my LHS (it's been a few weeks - and I'm sure they miss me)....;-)
JohnP2 is offline
Old 03-12-2012, 02:58 PM
cummins driver
My Feedback: (31)
cummins driver's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That wheel should work perfectly fromt he looks of it....
cummins driver is offline
Old 03-12-2012, 06:39 PM
JohnP2
JohnP2's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: cummins driver
The problem is that the servo arm does not fit anywhere on the wheel. Consequently, I'm at a loss on how the wheel would work.
JohnP2 is offline
Old 03-12-2012, 07:07 PM
proanti1
proanti1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Unscrew the turnbucle from the stock servo horn and screw it onto the round one.
proanti1 is offline
Old 03-12-2012, 07:11 PM
cummins driver
My Feedback: (31)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You dont need to mount the arm on the wheel. All you have to do is take the bolt out of the arm that holds it to the steering linkage and remove the arm all together, then put the bolt in one of the holes on the wheel that is the farthest to the outside, and put it all back together. Should work just fine I believe It looks different but functions exactly the same...
Old 03-12-2012, 07:18 PM
nitroexpress
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
type in double servo horn airtronics in any search engine and you're home.
Here is an example of the horns available to you. Doubt your LHS will have such a selection. Just pick one and you'll be running in no time.
http://www.amainhobbies.com/advanced...orn+airtronics
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
