why are tires so expensive?
WI
RE: why are tires so expensive?
ORIGINAL: hanly2
...he has a rustler vxl running 2s lipo...
It's like others have said, reglue the tires and use a new lock nut (or pick up the aluminum hexes depending on which hex is stripping), and see how that goes. If he's strips the wheel hex again, then there's a deeper problem.
ORIGINAL: Foxy
You think you got it bad in the small scales? Tyr a gasser. These are $82, A PAIR! http://www.amainhobbies.com/product_...perado-Wheel-2
ORIGINAL: SyCo_VeNoM
one of the reasons why I do not own a 1/5th scale RC
ORIGINAL: Foxy
Whya re they so expensive? cos we muppets continue to pay the inflated prices and other muppets keep playing the 'Tires have a lot of RnD!' card, which is frankly rubbish. They do have RnD, but no more than any other RC product.
HI
ORIGINAL: The_Shark
holy frijoles!!
ORIGINAL: Foxy
ORIGINAL: Phoenix XB Racer
Lol, you could buy a cheap 1/10 for the price of 4 tires.[img][/img]
ORIGINAL: The_Shark
holy frijoles!!
ORIGINAL: Foxy
OH
seems like I read somewhere that you can turn the tires inside out and put duct tape on the inside, then flip them back and glue them on to stop them from stretching so much and breaking the glue bead - or I could have imagined it!
#32
ORIGINAL: cheezer1222
I keep seeing this and thinking, ''Really?! He's destroying tires on 2s?''
That's true, they can get expensive, but that's also a fully assembled pair (beadlock rim, foam, tire). That whole assembly doesn't get purchased every time you wear out a set of tires.
ORIGINAL: hanly2
ORIGINAL: Foxy
#33
WI
ORIGINAL: phmaximus
Don't know about that, I'm looking $80 for 2 hostile slicks for my 5ive... That's just tyres and postage
You're looking at about $47 shipped for a set of hostile slicks to anywhere in the U.S. That's retail. I usually never buy new tires unless they're on sale. When ddm has hostile tires on their deal of the day, they're about $30 plus shipping. Still not super cheap, but hostile tires last me quite a while.
#34
dunno best tires I think I've ever had, and IMO worth it were the 2.2in dirthawgs that they had on the original HPI nitro MT1 I bought a extremely used MT1 3 years ago with the stock tires, they outlasted the RC, the rims they came on, are on their 3rd or 4th RC now, and STILL look brand friggin new. Seriously I grounded down a buggy tire on the one RC I put them on now, and are lasting.
#35
t-maxx tires live FOREVER, i have a 1999 version with the original tires and wheels and is driven on the street a lot, oftentimes driving on the sidewalls. NO wear at all.
#36
ORIGINAL: The_Shark
those are chevron style right? or are they the chunky tredded tires?
they make them still, but incremented them to Dirt Hawg II (probably made out of cheaper materials to make em actually wear )
odd thing though I run mine a lot on concrete which should grind that down, and I was doing royally skiding on them in one oof my Brushless RC's which I thought for sure would have done em in.
#37
pin tires suck for anything but loose dirt and the track.... wear wise.
i did this in about 15 minutes, after the pins where gone they really haven't gotten worse.. Jammin power for the win!
YES i run with a pipe, i just finished cleaning it.
#38
TN
Hey man, tires can be a pain especially buying used. When buying used, you don't know if they were glued on properly (like cleaning off the form oil from the rims first, using high quality ca, etc.) and they have already been beaten on. If you want a set of long lasting bashing tires, here are a couple tips. Harder compound tiresballoon less and wear longer. They are a much better Choice for your son. Soft compound tires are for high grip but wear out quickly andballoon much more which can easily break the glue or tear the bead. If gluing tires, always wash the rimsand tires first to remove any oil left from the manufacturing process. I hope this helps and good luck.
#39
MI
Busted hexes? Loosen the slipper some to decrease the shock loading.
Balooning tires? Definitely tape the next set- I did that to the Masher2Ks on my kid's Rusty and one tape job recently let go; it's comical the difference between them now.
The Masher2Ks have lasted really well; he also likes to do donuts and to 'splat dirt around'.
#40
ORIGINAL: tymtofly2
