Nitro Fuel tank cleaning
RE: Nitro Fuel tank cleaning
I used wd 40 on a buddies tank it had sat for a fews years sprayed it in let it sit over night and dumped it out the next day risned it with water and let it fully dry before doing anything with it
The best thing to use for cleaning out a fuel tank (of old oil residue, dirt, etc..) is fresh fuel itself, or you could use denatured alcohol. Denatured alcohol takes a little more "swishing around" to get all of the gunk dissolved into the alcohol, but it works. I mix my own fuel and have buckets of pure methanol so I just use that, although methanol is hard to find in some parts of the country, and probably overkill.
Using petroleum based solvents and oils like WD40 and chemicals like brake cleaner or carb cleaner are not wise to use as the o-rings in the lid will swell up from petroleum chemicals and the plastic can be weakened by the brake cleaner and carb cleaning solvents. I know from previous inexperience - I ended up with a tank that started to leak where the solvent ate a hole in the bottom of the tank. Of course not all fuel tanks are made of the same kind of plastic, so it may not affect your tank specifically. I just wouldn't do it to be safe.
Thanks, I already tried the WD-40 method but I took the take all apart to do it and I didn't use much. Do you guys use fuel filters on your cars?
ORIGINAL: Varhunter
ORIGINAL: Varhunter
ORIGINAL: Varhunter
Thanks, do those filters need to be replaced? or can you add a inline filter to it?
ORIGINAL: Varhunter
IL
The filter in the tank is similar to a bubble stone in a fish tank, you need fresh fuel as 1QwkSport2.5r suggested, then flush and backflush the stone filter in the tank, dump fuel, repeat.
Use a long fuel line and your mouth for lol suck and blow action for flushing/loosening up debris in the filter.
Always worked great for me.
