Servo help!
Servo help!
ok so today i got my new servo for my brushless crt.5
i pluged it in to center it to put on the horn and i notice when i steer it makes my motor twitch forward and backwards.
i pluged my old servo back in and no glitching when i steer
could this be overloading the bec? or maybe interference?
ESC-HPI(Castle) vapor pro
RX-Futaba r2004gf
TX-3pl
servo-MKS ds1210
RX-Futaba r2004gf
TX-3pl
servo-MKS ds1210
RE: Servo help!
Umm when you push on the arm it pulls power so it stays centered.
Sounds like it might be interference. I looked for specs, but couldn't find that servos current draw so its a hard call.
If it was drawing too much power I think it would act like the RC was powered off.
Try the servo in another RC and see if it causes any issues in that one as a test. If its just interference you could try a ferrite bead on the servos wire
RE: Servo help!
ORIGINAL: SyCo_VeNoM
Edit- yeah i know it pulls power to stay centered =P i meant that maybe because i wasnt using the remote it was just a bec problem
RE: Servo help!
well i plugged one of my 6v hump packs into the receiver with my 2s lipo hooked up to the ESC no more glitching and then unpluged the 6v pack and back to glitching so i guess its a BEC/hungry servo problem
think this would fix my problem http://www.amainhobbies.com/product_...tage-Protector
RE: Servo help!
Best option would be a 10a Castle BEC.... It's slight overkill but for the price it's well worth it....
A BEC itself can cause interference with more sensitive setups a step down regulator might be a better option.... Well depending on the receiver but I think yourse is 7.4v max so that type would only work with a 2s lipo
RE: Servo help!
Sorry I didn't see this before, I'd have told you straight away. It is browning out, you need a BEC, this is classic behaviour from that Castle ESC.
RE: Servo help!
Might want to try one of these, or make one your self,
http://www3.towerhobbies.com/cgi-bin...?&I=LXNRE0&P=7
I have been running one on my flux Hp, with a 1/5 scale 30kg steering servo,
Gives added boost to steering when the bec is getting it tight to supply the needed power to the servos,
http://www.youtube.com/watch?v=9svdZJU3qz8
RE: Servo help!
heres a short little video of it doing its thing http://www.youtube.com/watch?v=yX4A_...ature=youtu.be little hard to see but the receiver light never goes red so its not losing signal. i did try another one of my receivers and it did the same thing just the ESC lights do somthing
RE: Servo help!
ORIGINAL: Foxy
