redcat tornado s30
Reply
Old 01-02-2014, 03:02 AM
garry125
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default redcat tornado s30
I got a new car for holidays. Ive upgraded the shock towers. Car runs great after breaking it in. I have two problems i keep breaking the cheap plastic rims. Maybe because its cold. Lastly the grub screw that goes on front drive shaft from transmission keeps flying out. I hope lock tight works this time. Any advice?
garry125 is offline
Old 01-02-2014, 12:18 PM
Foxy
Moderator
Foxy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi n welcome.
Threadlock is the trick for the grub screws. Generally it should be applied to every metal to metal fastener on the car (and rarely is from the factory).
Foxy is offline
Old 01-02-2014, 12:54 PM
pcarluvr
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
And, if the grub screw tightens onto a flat spot, it helps to flatten the end of the grub to give more surface to hold to.
pcarluvr is offline
Old 01-12-2014, 10:18 PM
garry125
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
that did the trick. But know i think the rearend is blown. Does not spin. In you rotate the rear wheels the drive shaft does not rotate. One going to transmission
garry125 is offline
Old 01-14-2014, 03:05 PM
Cool_cris27
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The plastic is most likely breaking because its cold out and is generally stiffer. but you should try to make something to support some how not a lot of hop ups available for that car.
Cool_cris27 is offline
Old 01-16-2014, 02:21 AM
rcguy1411
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Check all the grub screws in drive shaft cups they may hace backed off as well
rcguy1411 is offline
Old 01-20-2014, 03:26 AM
garry125
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Okay wound up being the grub screws on rear drive cup was backed off. Everything is thread locked now. Actually i can replace everything on this car with aluminum parts. I did the shock tower upgrade the stock one bent jumping only a foot. You can get old part number and being its redcat cross reference it with hsp. Order hsp parts from china for 1/4 of the price!!
garry125 is offline
Old 01-20-2014, 09:25 PM
rcguy1411
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ya cant go wrong with the cost of replacement parts just paid $8.00 for a rear diff for my Volcano after about 4 years ive only killes a couple a arms and a few rims what i liked about the red cat is the engine buy back program $80.00 for a fresh engine cant go wrong at all
Old 07-05-2014, 05:26 AM
chumly222
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'm having the same problem with these cheap plastic rims. The hex nut keeps spinning out the plastic rim. The hex nut is about a 1/2 inch long but it only goes into the rim about 1/16 of an inch. That is just way to much stress to be putting on plastic rims. I'd like to know why redcat doesn't develope a rim that the hex nut sets deeper into the rim? Is there a aluminum rim available for this truck? It is a 12 mm hex nut. I don't want to change the size of the tires though.
chumly222 is offline
Old 07-06-2014, 04:43 PM
nitrosportsandrunner
nitrosportsandrunner's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
get the alloy 12mm hex. if the plastic hex strips, it usually strips out the wheel.
also, glue a plastic hex into the stripped wheels (super glue, I like the gel type) so you can keep using them.
the redcats are not the highest grade (that's why they cost less) but a little Loctite here, some grease there and checking all the hardware can keep them going for a long time.
don't forget to put some small pieces of fuel tubing on the output cup of the front diff. that will reduce the play on the front driveshafts, and keep them from poping out or binding when the wheels are fully turned.
Oh, and buy a decent steering servo. the stock ones are weak.
nitrosportsandrunner is offline
Old 07-06-2014, 04:49 PM
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
oh, might also help to buy some other wheel nuts. even tho the stock ones are lock nuts, I often had mine loosen up. when they get loose, the chance of damage to the wheel/hex is much greater. I think the rubber part of the lock nut is better with other brands. they are a normal size, so hpi/traxxas ect brand ones will work.
Reply
Display Modes
