help with team associated brushless motor
Reply
Old 07-24-2014, 05:43 PM
nitrosportsandrunner
nitrosportsandrunner's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default help with team associated brushless motor
Im working on my SC10rs, trying to maintain it as it has 20+ hours of use by now.
The trans/motor are not as quiet as they once were.
The trans is no problem, but the motor has me stumped. It is not like other BL motors I have worked on that has small screws holding the end of the motor on. I see no screws at all. The end with the wires looks like it can come off, but I don't see how?
Turning the motor by hand I can hear some dirt in the motor, it needs to be opened up so I can clean it out. Anyone know how? Is it pressed in? It is the stock SC10rs 3300kv motor.
nitrosportsandrunner is offline
Old 07-25-2014, 04:57 AM
collector1231
Moderator
collector1231's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have that motor. You can't take it apart, at least in my experience. A closed endbell and no vents makes the motor company think no maintenance.
collector1231 is offline
Old 07-25-2014, 05:34 AM
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
that's a nice theory....but it doesn't work that way. Even tho the side with the screw holes is up against the trans case, dirt still finds its way in there.
Guess I should start saving for a replacement motor.
Old 07-26-2014, 05:32 AM
collector1231
Moderator
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yeah, Reedy says nothing about it being servicable; http://www.teamassociated.com/pdf/ca...r-bl-motor.pdf
Not much saving to do! An 8.5 or 13.5 motor from Speed Passion on Express RC Hobby is only 39.99.
Old 07-31-2014, 12:25 AM
Maj_Overdrive
Maj_Overdrive's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The end bell on the wire side is likely just pressed in, can't exactly screw it in with the wires there. Try tapping on the motor shaft (pinion side) and see if the end bell will move. You could also try to loosen the end bell by rotating it slightly. To rotate it insert a flat blade screwdriver by the wires, contacting the end bell and give it a tap. Work the end bell back and forth and maybe it'll get loose enough to pop off when you tap the motor shaft.
Maj_Overdrive is offline
Old 07-31-2014, 12:35 AM
Maj_Overdrive
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sometimes a glue is used for press fit end bells. Could try a little heat to soften it up
Contact Us Archive Advertising Cookie Policy
